Hi all,
for my step sequencer project I will use 8 MCP23S17 SPI Port Expander to interface all the switches an LEDs. It operates with the Arduino UNO as exected and shown here: Hart gelötet!: Musik - Schritt für Schritt (Teil 2)
In my sketches I use the MCP23S17 Class von Cort Buffington: Arduino Playground - MCP23S17 Class for Arduino
Than I tried to do the same job with an Arduino Mega2560. Due to the other SPI-pins of the Mega (50...53) I build a new cable from my SPI-Board to the Arduino Mega. The cable is tested and it is ok. The Mega and the SPI-Board are powered up and the power levels are also ok.
But after uploading this test code:
#include <SPI.h>
#include <MCP23S17.h>
MCP inputchip(5);
MCP outputchip(0);
for (int i = 1; i <= 16; i++) {
inputchip.pinMode(i, HIGH);
inputchip.pullupMode(i, HIGH);
inputchip.inputInvert(i, HIGH);
outputchip.pinMode(i, LOW);
for (int i = 1; i <=16; i++) {
int value;
value = inputchip.digitalRead(i);
outputchip.digitalWrite(i, value);
If I push a switch, the appropriate LED lights up, when I use the UNO. But with the Mega, no reaction.
After that I thought it was something wrong with the hardware an I double-checked the board an made some test with a single MCP23S17 on a breadboard. The result was the same: UNO works, Mega don't work. The SPI pins are working correctly, because a test with a MicroSD card breakout board was successful.
Any idea what 's going on there? Is there maybe a problem with the library?
A web research was unsuccessful. A lot of people used the MCP with the UNO but it seems no one used one with the Mega.
Any help appreciated. Thanks in advance.
Chris
