Using the code below 690micro Amp is achieved during sleep mode and 2,500micro Amp when it is awake (LED on).
Is it possible to push down the power consumption lower during sleep mode?
attiny13a
attiny13 core
3v CR2032
LED connected to PB4 and grounded via 1meg resistor
#include <avr/sleep.h>
#include <avr/power.h>
#define LED PB4
 ISR(WDT_vect) {
 noInterrupts();          Â
 digitalWrite(LED,digitalRead(LED)^1);
 interrupts();      Â
 }//ISR()
void setup(){Â Â Â Â Â Â Â Â Â Â Â Â Â
 pinMode(LED, OUTPUT);
 WDTCR |= 32; //watchdog set for about 2 seconds Â
 WDTCR |= 64; //enable watchdog
 _SFR_MEM8(0x30)= 0x03; //disable Brown Out Detector Control Register
 _SFR_MEM8(0x35)&=0x83; //PUD disabled, Sleep enabled, Power Down modeÂ
 _SFR_MEM8(0x25)=2; //Power reduction timer enable
 interrupts();
}// setup()
void loop(){
 sleep_cpu(); Â
}//void loop()
this is a big "don't do that" for low power consumption. Even though it is common practice in arduino software, it is a bad idea to leave pins configured as inputs AND not connected to anything; they can easily "float" at non-digital signal levels (or even oscillate), causing unexpectedly high current consumption.
I'd be curious to hear if you actually see any change in consumption JUST by changing the pins to outputs.
And... I usually refrain from commenting on issues of programming style, but THIS is really awful:
Those registers, and their bits, are defined for you symbolically in avr/io.h (etc), which is included for you by the arduino system (the same place that _SFR_MEM8() is defined.) You should use them. (in fact, those registers are all defined as "_SFR_IO8(x)", which is not the same as _SFR_MEM8(), so perhaps those lines are not doing what you think they are doing AT ALL!)
Is there something else I can do to lower the power more?
Thank you for reading!
Modified Code now:
588 micro Amp when LED is off
2,166 micro Amp when LED is on
Other notes:
need to modify avrdude.conf (add attiny13a definition, just copy attiny13 and only change ID and Desc
iotn13a.h is used (some definitions are not included int attiny13.h)
unused pins activated pull-up resistor (Article 10.2.6 of attiny13a datasheet)
#define LED PORTB4
ISR(WDT_vect) {
PORTB ^= (1<<LED);
}//ISR()
 pinMode(PORT0,INPUT);   //Article 10.2.6 of attiny13a datasheet
 pinMode(PORT1,INPUT);
 pinMode(PORT2,INPUT);
 pinMode(PORT3,INPUT);
 pinMode(PORT5,INPUT);
 digitalWrite(PORT0,HIGH);
 digitalWrite(PORT1,HIGH);
 digitalWrite(PORT2,HIGH);
 digitalWrite(PORT3,HIGH);
 digitalWrite(PORT5,HIGH);
Â
 WDTCR |= (1<<WDP3) | (1<<WDTIE);   //Watchdog set for about 8 seconds Â
 ACSR |= (1<<ACD);          //Analog comparator off
 BODCR |= (1<<BPDSE)|(1<<BPDSE);   //Disable Brown Out Detector Control Register
 MCUCR |= (1<<SM1);          //Sleep mode to POWER DOWN
 PRR |= (1<<PRADC)|(1<<PRTIM0);   //Power reduction timer enable , ADC off
 DIDR0 |= (1<<AIN0D)|((1<<AIN1D));  //Digital input disable
Â
}// setup
void loop(){
 sleep_cpu(); Â
}//void loop()
Hello,
Thank you always for reading and for your kind insights.
Found a good link to reduce amperage during sleep mode to 4.5µA !.
However, I noticed that placing the code to setup() and loop() instead of main() yeilded different results.
Please see code and Amp reading below. Any thoughts on what is going on?
NOTES:
same attiny13a is used (same circuit also)
both codes have been uploaded several times
both codes show consistency of output after several uploads
all unused pin and reset pin are shorted to +3v of the cr2032
LED on =1700.0µA
LED off= 4.5µA
#include <avr/interrupt.h>
ISR(WDT_vect) {
 PORTB ^= 1<<PORTB4;
}//ISR
int main(void) {
 DDRB = 1<<DDB4;
 WDTCR |= (1<<WDP3); // (1<<WDP2) | (1<<WDP0);
 WDTCR |= (1<<WDTIE);
 sei(); // Enable global interrupts
 set_sleep_mode(SLEEP_MODE_PWR_DOWN);
for (;;) {
  sleep_mode();  // go to sleep and wait for interrupt...
 }//for
}//main
LED on =1830.0µA
LED off= 190.0µA
ISR(WDT_vect){
 PORTB ^= 1<<PORTB4;
}//ISR
void setup(){
DDRB = 1<<DDB4;
}//void setup
for (;;) {
}//for
}//main
Well, if you use setup() and loop(), you're letting the Arduino main() run, and that will turn on both timer0 and the ADC.
Using your own main(), those peripherals should be "never touched", and thus OFF.
In your initial code, you were explicitly turning things off (or at least attempting to!); what happened to that code in the latest example?
