Topic: 8x64 LED Martix MAX7119 and ESP-01 (Read 441 times) previous topic - next topic
Alkot
Hello Marco and all Others.)))
Can I try ESP-01 with MAX7119?
It has 4 GPIO pins:  0, 1(TX), 2  and 3(RX) and none of them CS CLK MOSI pins!
So I could not use SPI.h and  MD_MAX72XX(CS_PIN, MAX_DEVICES) function.
And will use MD_MAX72XX(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES) function.
Will it work like this?
What to do to continue using SPI.h?
If I would use SPI.h, Adafruit_GFX.h and Max72xxPanel.h, can i set DATA_PIN, CLK_PIN, CS_PIN "around" SPI.h?
Max72xxPanel.h does  not have function like MD_MAX72XX(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES)
Thank you
marco_c
You will need to use the class initialiser with the arbitrary pins (ie, not using SPI.h).
Quote
Yes this is the right approach. It will be slower than the hardware SPI but should work.
Can't give advice about the other libraries.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
Arduino++ blog https://arduinoplusplus.wordpress.com
ieee488
Why limit yourself to the ESP-01?
Alkot
Sorry, could not find what it means. "class initialiser with the arbitrary pins" - my knowledge is not so deep yet
Intend just use
Tx = GPIO 1
Rx = GPIO 3
will disconnect/connect while flashing
marco_c
The md_max72xx initialisation the specifies the pin numbers.
Alkot
Than you. That is very good (against Max72xxPanel.h) but still busy to make Cyrillic work with md_max72xx. Particularly with scrollText(char *p)/
