When reading back either the /GET /POST (Etc) request or just simply reading up until you hit CR/LF.
What's the best way to do it?.. in windows a 20k array to store the results in, is quite easy, but if you're limited what do you do? read as much as you can and dump the extra?.. eg, let's suppose you did something like /GET bleah bleah, and in the return you need certain values, eg maybe the content length, or maybe something else of use, or a command remotely to make it do something..
So what are the do's and dont's? for example let's suppose i had a 250 byte char array buffer, when that 250 is filled, do i go back to array[0] and start to fill it again? or do i simply accept that Arduino was never designed to be a webserver..... and you get around the limitations the best you can?
