Here is the first of my graphs.
This was generated over approximately 6.5 hours with readings sampled every 30 seconds. It is the same 65% rH environment shown in the first post.
Temperature tracked quite accurately to ambient and the humidity is ~5% higher than it should be.
Here is the slightly modified version of Glacial's code I used:
// Maurice Ribble
// 4-3-2008
// http://www.glacialwanderer.com/hobbyrobotics
// This code tests the SHT15 on the Arduino board.
// This app assumes your data pin is pin 10 and your your clock pin is pin 11.
// To run this app just attach HyperTerminal (or similar serial communications tool)
// to your Arduino board at 9600 bits per second. I also needed te set the
// flow control to none or I couldn't send commands to my Arduino board via HyperTerminal.
// Then press the 't' key to take a temperature reading or the 'h' key to take a
// humidity reading.
// These are commands we need to send to HSHT15 to control it
int gTempCmd = 0b00000011;
int gHumidCmd = 0b00000101;
int shiftIn(int dataPin, int clockPin, int numBits)
int ret = 0;
int i;
for (i=0; i<numBits; ++i)
digitalWrite(clockPin, HIGH);
delay(10); // I don't know why I need this, but without it I don't get my 8 lsb of temp
ret = ret*2 + digitalRead(dataPin);
digitalWrite(clockPin, LOW);
return(ret);
void sendCommandSHT(int command, int dataPin, int clockPin)
int ack;
// Transmission Start
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
digitalWrite(dataPin, HIGH);
digitalWrite(dataPin, LOW);
// The command (3 msb are address and must be 000, and last 5 bits are command)
shiftOut(dataPin, clockPin, MSBFIRST, command);
// Verify we get the coorect ack
pinMode(dataPin, INPUT);
ack = digitalRead(dataPin);
if (ack != LOW)
Serial.println("Ack Error 0");
if (ack != HIGH)
Serial.println("Ack Error 1");
void waitForResultSHT(int dataPin)
int i;
int ack;
for(i= 0; i < 100; ++i)
delay(10);
if (ack == LOW)
break;
if (ack == HIGH)
Serial.println("Ack Error 2");
int getData16SHT(int dataPin, int clockPin)
int val;
// Get the most significant bits
val = shiftIn(dataPin, clockPin, 8);
val *= 256;
// Send the required ack
// Get the lest significant bits
val |= shiftIn(dataPin, clockPin, 8);
return val;
void skipCrcSHT(int dataPin, int clockPin)
// Skip acknowledge to end trans (no CRC)
Serial.begin(9600); // open serial
int theDataPin = 7;
int theClockPin = 6;
char cmd = 0;
int ack;
float val;
float temp;
sendCommandSHT(gTempCmd, theDataPin, theClockPin);
waitForResultSHT(theDataPin);
val = getData16SHT(theDataPin, theClockPin);
skipCrcSHT(theDataPin, theClockPin);
temp = -40.0 + 0.018 * (float)val;
Serial.print(temp, DEC);
float humid;
sendCommandSHT(gHumidCmd, theDataPin, theClockPin);
humid = -4.0 + 0.0405 * val + -0.0000028 * val * val;
Serial.print("|");
Serial.println(humid, DEC);
delay(30000);
I've now begin the same process using the example code here: GitHub - practicalarduino/SHT1x: Arduino library to support SHT1x-series (SHT10, SHT11, SHT15) temperature / humidity sensors from Sensirion and in the same environment also sampling ever 30 seconds.
It's interesting to note that in switching the second code, the temperature dropped immediately to 71.7* F and the humidity climbed to 73.5%. The only change I made between the first test and beginning the second was uploading new code. Very strange.
Jacob
