Remember that i had some problems with a type B pinout KS0108, could this solve the problem?
Are there anyways yet to use this library to display decimal numbers like 3.14 ?
Hi, good to be back
Its worth trying to compile using the header file I uploaded to the playground yesterday (the cpp file is not changed).
Here is as sketch that shows how to print floating point to the GLCD.
* GLCDprint
* Basic print function test code for the Arduino KS0108 GLCD library.
#include <ks0108.h>
#include <Arial14.h> // font definitions
#define txtTopLine 2
#define txtBottomLine 48
void printDouble( double val, byte precision){
// prints val with number of decimal places determine by precision
// precision is a number from 0 to 6 indicating the desired decimial places
// example: printDouble( 3.1415, 2); // prints 3.14 (two decimal places)
GLCD.PrintNumber( (long)val); //prints the int part
if( precision > 0) {
GLCD.PutChar('.');
unsigned long frac;
unsigned long mult = 1;
byte padding = precision -1;
while(precision--)
mult *=10;
if(val >= 0)
frac = (val - int(val)) * mult;
frac = (int(val)- val ) * mult;
unsigned long frac1 = frac;
while( frac1 /= 10 )
padding--;
while( padding--)
GLCD.PutChar('0');
GLCD.PrintNumber(frac) ;
float drawSine(int angle){
float sine;
// if(angle <= 0)
sine = sin(PI / 180 * angle);
return sine;
void setup(){
GLCD.Init(NON_INVERTED); // initialise the library, non inverted writes pixels onto a clear screen
GLCD.SelectFont(Arial_14); // you can also make your own fonts, see playground for details
unsigned long startMillis;
void loop(){
startMillis = millis();
for( int i = 0; i < 128; i ++){
float s = sin(PI / 180 * i * 4) * 16;
GLCD.DrawLine(i, 32, i, 32+s,BLACK);
GLCD.GotoXY(4,txtBottomLine); // positon cursor
GLCD.Puts("Dur= "); // print a text string
float f = (millis() - startMillis) / 1000.0;
printDouble(f,3); // print a floating point number with 3 digits of precision
GLCD.Puts(" secs");
delay(2000);
GLCD.ClearScreen(); // clear the screen
I intend to enhance the GLCD library with a routine that clears the text background but I will wait for arduino version 0012 to be released because I want to use the print class that is planned for that release. Doing that will enable similar print methods in the text and graphic LCD libraries. But for now you need to explicitly clear the area where text is written as per the playground example using FillRect()
Code works fine
I will try my pinout B lcd when i find it, was looking for it yesterday but no where to be found.
I am anyways busy with my cheap lcd from Ebay, i noticed thet the new header is the same as my modefied so there should not be a diffrence if i try it.
Thanks for the report. Sounds like your other panel will work but I will wait until you actually get it going before adding it to the playground as a tested panel.
Hello!
I am developing some electronics for a little sailboat based on arduino diecimilia. I have decided to include a display and use the library for the KS0108.
I have been searching for a display and I have bought the following reference: LCD12864C from ledsee.com
You can find the datasheet searching the reference in the ledsee website
As you can imagine, I have had to change the wiring (hardware) and adapt the interface following the pinout detailed in the datasheet and the article in the Arduino Playground as they did not match.
Everything has worked reasonably well but the text or lines in the display do not look well. Text and Graphics move randomly and the text is hard to read. The example proposed in the library runs but the images are garbled.
I have reviewed the wiring three times.
What may I do to isolate the problem?
Thanks in advance,
Mario.
That's a pin configuration I have not seen before but lets see if we can get it going.
Can you take some pictures that show the problem. It will be easier for me to comment if I can see what is happening on the display. You can't directly post the pictures here but if you can put them on a site like flickr you can add links to the pictures in a post.
Also, did you change the ks0108.h file or did you just wire the pins so it matches the information in the playground?
Edit: My guess is that if you can read the text then your panel is probably wired to the correct pins. But I need to understand more about what you mean by “Text and Graphics move randomly and the text is hard to read”
Hello Mem,
I have posted a short video in youtube:
I also insert here the code for the sample program.
#include <ks0108.h>
int n=0;
int m=0;
void setup(){
if (n>128)
n=0;
m++;
if (m>64)
n=0;
m=0;
GLCD.ClearScreen();
GLCD.GotoXY(n,m); // position cursor
GLCD.Puts("Hi Mem!"); // write a string to the current cursor position
n++;
delay(100);
In the hardwired connections I just have respected the pins identityes and connect with the corresponding arduino layout.
The only software change in pinout has been to swap the chipselect pins.
Thanks again.
Mario.
Very strange! Two things come to mind as a possible cause:
There is a short (or open) circuit (perhaps intermittent) that is interfering with the signal lines, this could be on the LCD PCB or in the wiring.
The LCD is not able to respond to the timings provided by the library code.
I don't think its timing because the datasheet timings appear to be standard ks0108 values that have worked on other boards. That said, it may be that your board is overly fussy about timing. You can try to slow the library down by adding some extra delay in the delay450ns function in the ks0108.cpp file, but I would be surprised if that fixed it (but happy for you if it did). Don't forget to delete the ks0108.o file after a change:
static void delay450ns(void){ // delay 450 nanoseconds
asm volatile("nop\n\t"
"nop\n\t" // add these two more nops to slow things down a little
"nop\n\t"
"nop\n\t"
"nop\n\t"
"nop\n\t"
"nop\n\t"
Not sure what else to suggest, other than have a look a what happens when the pixel rate is slowed right down. You do that by uncommenting the following line in ks0108.cpp
//#define GLCD_DEBUG // uncomment this if you want to slow down drawing to see how pixels are set
You should then see each vertical block of up to 8 pixels being drawn. Perhaps a video of that may tell us more.
You may also want to modify your test so there is a fixed black rectangle somewhere on the screen so we can see if any of these are erased at random. Try this without clearing the screen on every write ( move your call to clearscreen in the if(m> 64) block and change n++ to n = n + 32, change m++ to M + = 12;
...If the number of "nop\n\t" increase your surprise, prepare for this...
To remove all little dots and leave the original example inside the library runing clearly, I have had to add 26. :o
The FPS are 6 and works perfect.
I appreciate very much your help and now I can keep on programming on mi project.
If I can help somehow to add this lcd module in the arduino playground for example, please let me know as I would collaborate gladly. I prefer you to do it after you find an explanation about what has happened with the signals timming in this model.
Thanks for everything,
Mario.
I am very happy you got it going and am surprised that your LCD needs such a long delay. Adding 26 nops makes the delay around 2 microseconds, the spec sheet says it that 450ns should be sufficient.
Anyway, I wonder if you can test some code that I could add to the library that would make it easier to support panels that need a long delay.
Could you comment out all the nops that you added and instead replace the code in the Enable function in ks0108.cpp with the following :
#define XTREME_ENABLE_DELAY 4
__inline__ void ks0108::Enable(void) {
fastWriteHigh(EN); // EN high level width: min. 450ns
delay450ns();
fastWriteLow(EN);
#ifdef XTREME_ENABLE_DELAY
for(volatile uint8_t i=0; i< XTREME_ENABLE_DELAY; i++);
#else
delay450ns();
#endif
You may need to increase the value of XTREME__ENABLE_DELAY from 4 to 5 or perhaps even 6, but if a value of 8 isnt' enough then I will suggest a slightly different place to add the delay.
Hello Mem,
I have made the changes in the .c file as you suggested, the delay seems not to be placed in the right position. The text is not working properly again even with the variable set to 10.
I have returned to the previous "26 nops" version.
Tell me what else we can do.
Regards,
Mario.
Ok, lets put the Enable(void) method back the way it was and increase the generic delay. This will do the same things as your added nops but uses less code, and it can be easily enabled or disabled if I put it into the distributed file.
#define BIG_DELAY 4 // uncomment this to increase the delay to by a few microseconds
#ifdef BIG_DELAY
for(volatile uint8_t i=0; i< BIG_DELAY ; i++);
#else
"nop\n\t"
"nop\n\t"
"nop\n\t" "nop\n\t"
#endif
First post - so here goes. Firstly many thank mem for a great library - my project would not be possible without this.
I have a very similar problem to Mario_B so thought I would chip in my findings.
I am using a KS0108B based 128x64 lcd from Sure Electronics
(type B pinout ). Bought from ebay - cheap as chips IF it can be made to work OK.
I had to add 48 (yes count them!) nop instructions to get a steady display at which point my FPS count is 5.
Like Mario_B using XTREME_ENABLE_DELAY method did not work even when using large values (e.g. 200)
Using the BIG_DELAY method works a treat and I can decrease BIG_DELAY to 1 - at which point my FPS is 5.
Other thoughts/advice needed-
Is an FPS of 5 likely to impact my project - ie should I look for a better lcd before proceeding?
Could my wiring be too long. I'm running on a solderless breadboard currently and the wires between arduino and lcd are about 5 inches long.
Similar problem (with a different lcd) reported in sparkfun forum
A responder thinks that this might be due to "reflections" and that "terminating with a couple of 50 ohm resistors might help". I can try this out if someone can tell me in detail how to wire this up.
Thanks
(had included links to sparkfun and sure electronics but system wont allow me to post these in first post )
Hi Rower, thanks for the information. It is possible that very long cable lengths could be an issue, but I use 5 inch long wires and mine works great, so I think it unlikely that is the problem. Anyway, don't use 50 ohm resistors, that will put much too much load on the arduino pins.
I think I may have a CFAG12864B LCD buried away somewhere here, if that is the same as yours I will try it and see if I also need the big delay.
Running with an FPS of 5 is not a problem if your sketch runs fast enough.
I found the GLCD panal I got from Sure electronics a while ago but it's not the same as Rower's (mine is a type 'A' Crystalfontz panel), so I am no clearer on why some of the type 'B' panels need extra delays.
For those reading this thread looking to decide which panel to get, I think the type 'A' panels (+v on pin 1, data0 on pin4 etc) have been easier to integrate then type 'B' panels.
I wonder if there would be much interest if I offered to supply a full performance ready to run 128x64 GLCD panel that included wired connectors and the little PCB with contrast and backlight resistors
I think I could probably do them for around $20 plus shipping if there was enough interest. PM me if you want one (don't post here, lets keep this thread to technical discussions)
