Well, that's progress...
Not sure why the graphs don't show...
Can you please post a few screenshots of your cacti config? Specifically a screenshot of the page shown on the 5th picture in my post (the one with all the screenshots). Then, on that same page click on the first item in the list on the top (should be the graph item) and post another screenshot of that page.
I not really sure how to post screen shots..I am posting images..
Graph template screen shots (image graph1 and graph2)
Item #1 current reading (image graph3)
Humidity graph setting (image graph 5, graph6)
Temperature graph setting (image graph7,graph8)
I think the problem is shown on the first screenshot. You only have GPRINT items in your graph template. These are text prints. You need to add an AREA item (filled graph). See the 2nd and 3rd (from bottom) of my screenshots...
Update.. There is grab in data cause I disconnected the sensor.
I was looking at your watchdog circuit very useful.. :)I am facing the same prob..SNMP gets stuck with unknow packet. That's my next step...
Hi everyone, I'm an SNMP newbie.
However, I've added basic trap support.
If you're interested, I've attached the patches to this post.
Here is how you'd use it:
Sending the trap:
void send()
SNMP_PDU pdu;
char agent[] = {192, 168, 0, 177};
const uint8_t manager[] = {192, 168, 0, 3};
pdu.OID.size = 2;
pdu.OID.data[0] = 7;
pdu.OID.data[1] = 7;
pdu.address = agent;
pdu.trap_type = SNMP_TRAP_ENTERPRISE_SPECIFIC;
pdu.specific_trap = 1;
pdu.time_ticks = 0;
/* the size of the data you will add at the end of the packet */
pdu.trap_data_size = 10;
/* the function that adds this data */
pdu.trap_data_adder = add_trap_data;
Agentuino.sendTrap(&pdu, manager);
yazgoo:
Has anyone been able to successfully merge these changes into the library? 8/12 of the hunks failed when i tried to apply the files as a patch and I can't figure out where the failed pieces are supposed to go.
Hi, this is my first Arduino project after testing some example sketches and making an LCD display menu. I would like to read a few predefined MIB’s from a modem with SNMP get-commands. First I want to display a MIB in my serial monitor and finally I’d like to display them on my LCD. The modem I am using for this test is configured for use with SNMP V2c. The modem is not in a “live” environment. When I use a MIB browser I can see one of predefined MIB’s at this location: 1.3.6.1.2.1.10.127.1.1.1.1.6.3. The MIB contains a value around -490.
When I check my serial monitor using the code below the only thing I see is “SNMP Agent Initalized…” Can someone tell me how I can display a MIB there?
I used the sketch from the “Agentuino SNMP Astronomy Weather Station” and I adapted it for my own needs. I compared it with the Agentuino example sketch and the only difference I see was an “F” every time this function is used: Serial << F("SNMP Agent Initalized...") << endl;
Can someone tell what the “F” is needed for?
* Adaptation of
* Agentuino SNMP Astronomy Weather Station
* http://openhardware.gridshield.net/home/arduino-snmp-temperature-sensor
* example from "yesyesserver.co.uk/temp/wheater_station"
#include <Streaming.h> // Include the Streaming library
#include <Ethernet.h> // Include the Ethernet library
#include <SPI.h>
#include <MemoryFree.h>
#include <Agentuino.h>
#include <Flash.h>
#define DEBUG
// SNMP stuff
byte count=0; // count number of processed SNMP requests
// parameters for the Ethernet library
static byte mac[] = { 0x90, 0xA3, 0xDA, 0x0E, 0xAD, 0x3f };
static byte ip[] = { 192, 168, 1, 200 };
static byte gateway[] = { 192, 168, 1, 1 };
static byte subnet[] = { 255, 255, 255, 0 };
// must-have RFC1213-MIB OIDs (taken from agentuino sample sketch)
// .iso.org.dod.internet.mgmt.mib-2.system.sysDescr (.1.3.6.1.2.1.1.1)
static char sysDescr[] PROGMEM = "1.3.6.1.2.1.1.1.0"; // read-only (DisplayString)
// .iso.org.dod.internet.mgmt.mib-2.system.sysObjectID (.1.3.6.1.2.1.1.2)
static char sysObjectID[] PROGMEM = "1.3.6.1.2.1.1.2.0"; // read-only (ObjectIdentifier)
// .iso.org.dod.internet.mgmt.mib-2.system.sysUpTime (.1.3.6.1.2.1.1.3)
static char sysUpTime[] PROGMEM = "1.3.6.1.2.1.1.3.0"; // read-only (TimeTicks)
// .iso.org.dod.internet.mgmt.mib-2.system.sysContact (.1.3.6.1.2.1.1.4)
static char sysContact[] PROGMEM = "1.3.6.1.2.1.1.4.0"; // read-write (DisplayString)
// .iso.org.dod.internet.mgmt.mib-2.system.sysName (.1.3.6.1.2.1.1.5)
static char sysName[] PROGMEM = "1.3.6.1.2.1.1.5.0"; // read-write (DisplayString)
// .iso.org.dod.internet.mgmt.mib-2.system.sysLocation (.1.3.6.1.2.1.1.6)
static char sysLocation[] PROGMEM = "1.3.6.1.2.1.1.6.0"; // read-write (DisplayString)
// .iso.org.dod.internet.mgmt.mib-2.system.sysServices (.1.3.6.1.2.1.1.7)
static char sysServices[] PROGMEM = "1.3.6.1.2.1.1.7.0"; // read-only (Integer)
// custom OIDs -> Aan te passen
static char MyMib[] PROGMEM = "1.3.6.1.2.1.10.127.1.1.1.1.6.3"; // The MIB I want to read
// RFC1213 local values (taken from agentuino sample sketch) -> Aan te passen
static char locDescr[] = "Arduino based SNMP Astronomy Weather Station"; // read-only (static)
static char locObjectID[] = "1.3.6.1.2.1.10.127.1"; // read-only (static)
static uint32_t locUpTime = 0; // read-only (static)
static char locContact[20] = "yesyes"; // should be stored/read from EEPROM - read/write (not done for simplicity)
static char locName[20] = "Agentuino"; // should be stored/read from EEPROM - read/write (not done for simplicity)
static char locLocation[20] = "Maidenhead, UK"; // should be stored/read from EEPROM - read/write (not done for simplicity)
static int32_t locServices = 7; // read-only (static)
uint32_t prevMillis = millis(); // used for system uptime calculation
char oid[SNMP_MAX_OID_LEN]; // will hold the OID of an SNMP request
SNMP_API_STAT_CODES api_status; // agentuino SNMP status
SNMP_ERR_CODES status;
// SNMP callback function, taken from agentuino sample sketch and extended to include my custom OIDs
void pduReceived() // is being called when an SNMP packet has been received
SNMP_PDU pdu;
#ifdef DEBUG
Serial << "UDP Packet Received Start.." << " RAM:" << freeMemory() << endl;
#endif
api_status = Agentuino.requestPdu(&pdu);
// check if valid packet
if ( (pdu.type == SNMP_PDU_GET || pdu.type == SNMP_PDU_GET_NEXT || pdu.type == SNMP_PDU_SET)
&& pdu.error == SNMP_ERR_NO_ERROR && api_status == SNMP_API_STAT_SUCCESS )
pdu.OID.toString(oid);
Serial << "OID: " << oid << endl;
if ( strcmp_P(oid, sysDescr ) == 0 )
// handle sysDescr (set/get) requests
if ( pdu.type == SNMP_PDU_SET )
// response packet from set-request - object is read-only
pdu.type = SNMP_PDU_RESPONSE;
pdu.error = SNMP_ERR_READ_ONLY;
// response packet from get-request - locDescr
status = pdu.VALUE.encode(SNMP_SYNTAX_OCTETS, locDescr);
pdu.error = status;
#ifdef DEBUG
Serial << "sysDescr..." << locDescr << " " << pdu.VALUE.size << endl;
#endif
else if ( strcmp_P(oid, sysObjectID ) == 0 )
// handle sysName (set/get) requests
// response packet from get-request - locUpTime
status = pdu.VALUE.encode(SNMP_SYNTAX_OCTETS, locObjectID);
pdu.error = status;
#ifdef DEBUG
Serial << "ObjectID" << locObjectID << " " << pdu.VALUE.size << endl;
#endif
//… had to shorten the code for I can post only 9500 characters in the Arduino forum. Check out the full code at the web page shown at the beginning of this example.
// add more custom OID blocks here
// oid does not exist
// response packet - object not found
pdu.error = SNMP_ERR_NO_SUCH_NAME;
Serial << "Unknown OID" << endl;
Serial << "Sending response..." << endl;
Agentuino.responsePdu(&pdu);
count++;
// packet not valid, send GENERAL_ERROR response. Required, otherwise the invalid packet
// will get stuck in the buffer and processed over and over again
Serial << "Unknown Packet!!" << endl;
Serial << "PDU Type: " << pdu.type << " PDU Error: " << pdu.error << " API status: "<< api_status << endl;
pdu.error = SNMP_ERR_GEN_ERROR;
Serial << "Sent 'GENERAL_ERROR' response" << endl;
Serial << "freeing PDU.." << " RAM:" << freeMemory() << endl;
Agentuino.freePdu(&pdu);
Serial << "UDP Packet Received End.." << " RAM:" << freeMemory() << endl;
Ethernet.begin(mac, ip);
// start Agentuino SNMP library
api_status = Agentuino.begin();
if ( api_status == SNMP_API_STAT_SUCCESS )
Agentuino.onPduReceive(pduReceived); // register callback function that is being called when an SNMP packet has been received
delay(10);
Serial << "SNMP Agent Initalized..." << endl;
delay(10);
Serial << "SNMP Agent Initalization Problem..." << status << endl;
Serial.print(MyMib);
// listen for / handle incoming SNMP requests
Agentuino.listen();
// sysUpTime - The time (in hundredths of a second) since
// the network management portion of the system was last
// re-initialized.
if ( millis() - prevMillis > 1000 ) {
// increment previous milliseconds
prevMillis += 1000;
// increment up-time counter
locUpTime += 100;
Wouter202:
I believe the F function is part of the Flash library. "SNMP Agent Initialized..." is probably stored in EEPROM to save on memory. The F function pulls it out of EEPROM so that it can be sent to the Serial port.
MIB: File that contains a list of OIDs and their definitions, kind of a dictionary.
OID: Object Identifier, think of it as an encoded variable name.
Agent: An SNMP device that responds to GET and SET commands and can also send out traps/notifications.
Manager: An SNMP device or application that sends out GET and SET commands and listens for traps/notifications.
Versions: There are three common SNMP versions used today. 1, 2c, and 3.
The Agentuino library allows your Arduino to act as an SNMP v1 Agent. It sounds like you are wanting to use your Arduino as a v2c Manager, is that correct?
Hi there Rex, thank you for your reply. So maybe I should be placing the "F" in front every time Serial is called. Because in the SNMP Astronomy Weather Station example that wasn't the case?
Do you think it would be possible to use the Arduino as a v2c SNMP Manager with the Agentuino code? I think the GET-command is about the same in V1 as in V2. But maybe the code would need some adaptation then?
Wouter202:
You can either include the Flash library or alter all of the serial calls, up to you. All it is doing is writing to the serial port.
It would be possible to adapt the Agentuino library but you're going to have to get very familiar with the SNMP packet structure. I spent about 3 weeks learning about SNMP, bought an SNMP software suite, and made heavy modifications to the Agentuino library to bring it up to v2c specs (and make it a little easier to use with traps).
I haven't had a need to make it a manager but thinking off the top of my head (I don't have the Agentuino library open right now) it would go something like this:
Take the method that is used to send the get/set responses and use that as a template for sending a GET or SET PDU.
The PDU parsing method should work for parsing the response PDUs that will come back since they follow the same structure.
Find all of the references to the PDU version attribute, I believe it was hardcoded for v1, a value of 0. v2c has a value of 1.
v2c traps may work as well since, unlike v1 traps, they follow the standard PDU structure.
I don’t think I will need traps to get the info out of my mib?
Thank you for looking into this with me. And thank you for sharing your knowledge, this is all pretty new for me. I would really like to get this working.
