I have tried to use pha555 version and can not get anything out of it think it must be wiring. looking at the code and the diagram I am confused.
This is what I did I use two analog inputs and output to a lcd.
This is my code if you can help build onto it let me know.
Thanks all,
Hugh
Analog input, analog output, serial output
Reads input pin A0 for temp from sensor and outputs degress f
Reads input pin A1 for humidity from sensor and outputs in %
Reads an analog input pin, maps the result to a range from 0 to 255
and uses the result to set the pulsewidth modulation (PWM) of an output pin.
Also prints the results to the serial monitor.
The circuit:
- Temp sensor output connected to analog pin 0.
Humidity sensor output connected to analog pin 1
- LED connected from digital pin 9 to ground
LCD connections reset connected to digital pin 12
enable = D11
DB4 = D5
DB5 = D4
DB6 = D3
DB7 = D2
created 7 Oct 2010
Modified 7 Oct 2010
by Hugh Coleman
This example code is in the public domain.
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// These constants won't change. They're used to give names
// to the pins used:
const int analogInPin = A0; // Analog input on pin A0 for temp reading
const int analogOutPin = 9; // Analog output pin that the LED is attached to
const int analogInPinOne = A1; // Analog input pin A1 for humidity reading
int tempValue = 0; // value read from sensor output
int outputValue = 0; // value output to the PWM (analog out)
int humidValue = 0;
int OutPutValueOne = 0;
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
lcd.clear();
// initialize serial communications at 9600 bps:
// read the analog in value:
tempValue = analogRead(analogInPin); //reads the value on analog pin a0:
humidValue = analogRead(analogInPinOne); //reads the value on analog pin a1
// map it to the range of the analog out:
outputValue = map(tempValue, 0, 1023, 0, 255);
// change the analog out value:
analogWrite(analogOutPin, outputValue);
// print the results to the serial monitor:
Serial.print("sensor = " );
Serial.print(tempValue);
// sets the cursor and prints Temp:
lcd.setCursor(2,0);
lcd.print("Temp"); //outputs Temp to lcd:
// sets the cursor and prints the current temp in F:
lcd.setCursor(11, 0);
lcd.print(tempValue*.155); //calls the tempValue multiplies it times .155:
// sets the cursor and prints Humidity:
lcd.setCursor(0, 1);
lcd.print("Humidity"); //outputs Humidity to lcd:
// sets the cursor and prints the current relative humidity:
lcd.setCursor(11, 1);
lcd.print(humidValue/10); //analog a1 input divided by 10:
// sets the cursor and prints the % sign
lcd.setCursor(14, 1);
lcd.print("%");
// delay 3 seconds:
delay(3000);
Serial.print("\t output = ");
lcd.clear();
Serial.println(outputValue);
