Hello,
For a while now I have been using my own implementation for rotary encoders. I always thought that the following library was only for Teensy.
https://www.pjrc.com/teensy/td_libs_Encoder.html
Realizing that it is not, I attempted to implement it on the Due. I am without luck. I change Basic example to the pins I have been using for a while now, and the nothing is happening when I rotate the encoder.
My board and encoders are fine because I can see the signals with a scope and I have been using these boards for a year now.
I am using pins 18 and 19, which look to valid (I checked the pin configuration file) of the library.
I am using software version 1.6.3 with the teensyduino add-on.
EDIT:
The Basic example does not work, but the NoInterrupts example works. I would like to get the Basic example working. I feel like this is an internal problem.
Thanks,
Daniel
