I want to switch the main power supply to a gps reciever(UP501) on and off. The gps reciever uses 1 pin for ground, 1 pin for back up power supply and 1 pin for main power supply. Using plain digital pins doesn't work, because the gps draws about 30mA on 3,3V. The back up power supply pin is always connected to 3,3V.
To make it work I want to use a transistor to switch the main power supply on and off. But my lack of knowledge about transistor isnt helping much. Can anybody help me with this?
Im using an arduino clone based on the arduino pro (3,3V;8MHz) w/ Atmega328.
No, this won't work, a p-channel MOSFET or PNP switching transistor to do high-side switching is required. An n-channel
or NPN device can only do low-side switching on the ground which is incompatible with maintaining the backup 3.3V
supply. Search for high-side switching, p-channel and/or PNP.
