/Users/user/Dropbox/Projects/Arduino/libraries/IMU/I2Cdev.cpp: In static member function 'static int8_t I2Cdev::readBytes(uint8_t, uint8_t, uint8_t, uint8_t*, uint16_t)':
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/I2Cdev.cpp:278: error: 'class TwoWire' has no member named 'write'
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/I2Cdev.cpp:284: error: 'class TwoWire' has no member named 'read'
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/I2Cdev.cpp: In static member function 'static int8_t I2Cdev::readWords(uint8_t, uint8_t, uint8_t, uint16_t*, uint16_t)':
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/I2Cdev.cpp:418: error: 'class TwoWire' has no member named 'write'
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/I2Cdev.cpp:427: error: 'class TwoWire' has no member named 'read'
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/I2Cdev.cpp:430: error: 'class TwoWire' has no member named 'read'
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/I2Cdev.cpp: In static member function 'static bool I2Cdev::writeBytes(uint8_t, uint8_t, uint8_t, uint8_t*)':
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/I2Cdev.cpp:601: error: 'class TwoWire' has no member named 'write'
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/I2Cdev.cpp:607: error: 'class TwoWire' has no member named 'write'
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/I2Cdev.cpp: In static member function 'static bool I2Cdev::writeWords(uint8_t, uint8_t, uint8_t, uint16_t*)':
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/I2Cdev.cpp:651: error: 'class TwoWire' has no member named 'write'
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/I2Cdev.cpp:658: error: 'class TwoWire' has no member named 'write'
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/I2Cdev.cpp:659: error: 'class TwoWire' has no member named 'write'
#define I2CDEV_IMPLEMENTATIONÂ Â Â I2CDEV_ARDUINO_WIRE
to
#define I2CDEV_IMPLEMENTATIONÂ Â Â I2CDEV_ARDUINO0_WIRE
errors:
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/Wire.cpp:24:19: error: twi.h: No such file or directory
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/Wire.cpp: In member function 'void TwoWire::begin()':
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/Wire.cpp:60: error: 'twi_init' was not declared in this scope
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/Wire.cpp: In member function 'void TwoWire::begin(uint8_t)':
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/Wire.cpp:65: error: 'twi_setAddress' was not declared in this scope
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/Wire.cpp:66: error: 'twi_attachSlaveTxEvent' was not declared in this scope
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/Wire.cpp:67: error: 'twi_attachSlaveRxEvent' was not declared in this scope
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/Wire.cpp: In member function 'uint8_t TwoWire::requestFrom(uint8_t, uint8_t)':
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/Wire.cpp:83: error: 'twi_readFrom' was not declared in this scope
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/Wire.cpp: In member function 'uint8_t TwoWire::endTransmission()':
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/Wire.cpp:115: error: 'twi_writeTo' was not declared in this scope
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/Wire.cpp: In member function 'void TwoWire::send(uint8_t)':
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/Wire.cpp:143: error: 'twi_transmit' was not declared in this scope
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/Wire.cpp: In member function 'void TwoWire::send(uint8_t*, uint8_t)':
/Users/user/Dropbox/Projects/Arduino/libraries/IMU/Wire.cpp:160: error: 'twi_transmit' was not declared in this scope
There is a copy, in your directory, of the Arduino core library composed of Wire.cpp and Wire.h. You need to either get rid of them and possibly break that library, or get rid of the core Wire library and possibly break other sketches.
Can i ask how do you go about breaking the copy of the library or getting rid of it?
I was trying this stuff too and I encounter this problem,however it cant be resolved. Please help
