Error when convert sketch from xx.pde too xx.ino
Hi all,
I wrote a Arduino sketch for version 0023. It's works well. Now I update too version 1.0.2. Change the extension of the sketch from xx.pde too xx.ino
But when I compile I get errors.
Who can help me?
Jack
Below the sketch:
//Weerstation
#include <SHT1x.h>
#include <Wire.h>
#include <BMP085.h>
BMP085 bmp;
// Specify data and clock connections and instantiate SHT1x object
#define dataPin  4
#define clockPin 5
SHT1x sht1x(dataPin, clockPin);
LiquidCrystal_I2C lcd(0x27,20,4);  // set the LCD address to 0x27 for a 20 chars and 4 line display
  bmp.begin();
  lcd.init();                      // initialize the lcd
  lcd.begin(20,4);
  lcd.clear();
  lcd.backlight();
  float temp_c;
  float humidity;
  // Read values from the sensor
  temp_c = sht1x.readTemperatureC();
  humidity = sht1x.readHumidity();
  // Print the values to the serial LCD
  lcd.setCursor(0,0);  //1ste rij LCD
  lcd.print("T1 ");  //Temperatuur binnen
  lcd.print(temp_c, 1);
  lcd.print((char)223);  //Graden symbool
  lcd.print("C");
  lcd.setCursor(11,0);  //1ste rij LCD
  lcd.print("RV1 ");   //Luchtvochtigheid binnen
  lcd.print(humidity, 1);
  lcd.print("%");
  lcd.setCursor(0,2);  //3de rij LCD
  lcd.print("LD ");   //Luchtdruk
  lcd.print((bmp.readPressure()/100)+1);
  lcd.print("mBar");
  delay(5000);
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
BMP085.cpp (7.48 KB)
BMP085.h (2.5 KB)
SHT1x.cpp (5.86 KB)
SHT1x.h (1000 Bytes)
Hi All,
More attachements for the library.
Jack
LiquidCrystal_I2C.cpp (8.09 KB)
LiquidCrystal_I2C.h (3.27 KB)
It would help if you posted the errors and read the sticky topic in this section.
When I compile the sketch I get the next errors:
In file included from Weerstation.ino:5:
R:\Mijn Documenten\Arduino\libraries\Weerstation/SHT1x.h:15:22: error: WProgram.h: No such file or directory
In file included from Weerstation.ino:4:
R:\Mijn Documenten\Arduino\libraries\Weerstation/LiquidCrystal_I2C.h:81: error: conflicting return type specified for 'virtual void LiquidCrystal_I2C::write(uint8_t)'
R:\Mijn Documenten\Program Files\Arduino\arduino-1.0.2\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)'
Jack
That is covered in the sticky topic I told you to read. Have you read it?
Why have you not modified you original post to include code tags.
I haven't read the sticky topic.
I don't have experience with programming.
Therefore I have only change the extension of the sketch from .pde to .ino
Jack
jack100:
Well if you are not willing to read the sticky which tells you what to do then why should I repeat that information.
The fact that you don't have any programming experience does not prevent you from reading does it?
You have to change a file in the libary and the sticky tells you what.
Some errors I have tackled.
Only this 2 errors continue:
R:\Mijn Documenten\Arduino\libraries\Weerstation\LiquidCrystal_I2C.cpp:219: error: prototype for 'void LiquidCrystal_I2C::write(uint8_t)' does not match any in class 'LiquidCrystal_I2C'
R:\Mijn Documenten\Arduino\libraries\Weerstation/LiquidCrystal_I2C.h:81: error: candidate is: virtual size_t LiquidCrystal_I2C::write(uint8_t)
Jack
That one is covered, too. The LiquidCrystal_I2C hasn't been updated for 1.0+ use. Edit the header file for the library, and change the return type of the write() method from void to size_t. Edit the source file and make the same change. At the end of the write() method add a return statement to return a value, usually 1.
Paul,
I don't understand exactly what you means.
Here the 2 files. LiquidCrystal_I2C.h and LiquidCrystal_I2C.cpp
Paul, will you change both files for me?
Jack
Hi all,
All the errors are solved!
Jack
