erictronico:
HI!
thank you all for sharing your knowledge and time, as a contribution I can say: you do not need the external 32K oscillator , my Arduino DUE have not incorporated and works perfectly (this is for use with the RTC that I think it is better to use an external one for the possibility of a battery backup as DS1307).
zhivkec
did you compiled a sketch in ARDUINO IDE 1.5x and you load in a ATSAM3X8CA?
I wanted to do that in the beginning, but due to lack of information and components (in my country do not get these chips) finally I didn't , but it was in my plans, I wish you could confirm this.
greetings
Erick
I compiled it on arduino 1.5.8.
When I plug usb connector to windows machine I get following in my device manager:
In arduino IDE I can see board as:
The BOM is here:
Report Written : Tuesday, June 16, 2015 03:17
Design Path : C:\Users\klemen\Dropbox\ArduinoDue\ArduinoDue.sch
Design Title :
Created :
Last Saved : 15.9.2014 3:08:54
Editing Time : 3569 min
Units : thou (precision 2)
Bill of Materials generated with DesignSpark PCB - www.DesignSpark.com/pcb
"Ref Name","Qty","Component","Value","Package","Manufacturer","MPN","RS Part Number","Other Part Number","Description"
"R8","1","1206","100k","1206","","","","","Resistor"
"C15","1","Capacitor_1206","1uF","1206_Klemen","","","","","Capacitor"
"C1","1","Capacitor_1206","10nF","1206_Klemen","","","","","Capacitor"
"C10","1","Capacitor_1206","10pF","1206_Klemen","","","","","Capacitor"
"C11","1","Capacitor_1206","22pF","1206_Klemen","","","","","Capacitor"
"C12","1","Capacitor_1206","22pF","1206_Klemen","","","","","Capacitor"
"C13","1","Capacitor_1206","22pF","1206_Klemen","","","","","Capacitor"
"C14","1","Capacitor_1206","22pF","1206_Klemen","","","","","Capacitor"
"C6","1","Capacitor_1206","100nF","1206_Klemen","","","","","Capacitor"
"C16","1","Capacitor_1206","100nF","1206_Klemen","","","","","Capacitor"
"C17","1","Capacitor_1206","100nF","1206_Klemen","","","","","Capacitor"
"C18","1","Capacitor_1206","100nF","1206_Klemen","","","","","Capacitor"
"C19","1","Capacitor_1206","100nF","1206_Klemen","","","","","Capacitor"
"C20","1","Capacitor_1206","100nF","1206_Klemen","","","","","Capacitor"
"C21","1","Capacitor_1206","100nF","1206_Klemen","","","","","Capacitor"
"C7","1","Capacitor_1206","100nF","1206_Klemen","","","","","Capacitor"
"C22","1","Capacitor_1206","100nF","1206_Klemen","","","","","Capacitor"
"C23","1","Capacitor_1206","100nF","1206_Klemen","","","","","Capacitor"
"C24","1","Capacitor_1206","100nF","1206_Klemen","","","","","Capacitor"
"C25","1","Capacitor_1206","100nF","1206_Klemen","","","","","Capacitor"
"C9","1","Capacitor_1206_Electrolyte","2.2uF","SMD_Electrolyte","","","","","Capacitor"
"C8","1","Capacitor_1206_Electrolyte","4.7uF","SMD_Electrolyte","","","","","Capacitor"
"CONN2","1","CONN15X2","","DIL","","","","",""
"PL3","1","CONN_SIL_2","","DSC","","","","","2 way Pin Header"
"PL4","1","CONN_SIL_2","","DSC","","","","","2 way Pin Header"
"PL5","1","CONN_SIL_2","","DSC","","","","","2 way Pin Header"
"PL6","1","CONN_SIL_2","","DSC","","","","","2 way Pin Header"
"PL7","1","CONN_SIL_2","","DSC","","","","","2 way Pin Header"
"PL8","1","CONN_SIL_2","","DSC","","","","","2 way Pin Header"
"Q2","1","CRYSTALHC49UV","12MHz","HC49U-V","","","","","CrystalsVarious standard crystals. Proven footprints. Spark Fun Electronics SKU : COM-00534"
"Q1","1","CRYSTALTC26H","32kHz","TC26H","","","","","CrystalsVarious standard crystals. Proven footprints. Spark Fun Electronics SKU : COM-00534"
"Ground1","1","Ground","","SPICE","","","","",""
"Ground2","1","Ground","","SPICE","","","","",""
"Ground3","1","Ground","","SPICE","","","","",""
"Ground4","1","Ground","","SPICE","","","","",""
"Ground5","1","Ground","","SPICE","","","","",""
"Ground6","1","Ground","","SPICE","","","","",""
"Ground7","1","Ground","","SPICE","","","","",""
"Ground8","1","Ground","","SPICE","","","","",""
"Ground9","1","Ground","","SPICE","","","","",""
"Ground10","1","Ground","","SPICE","","","","",""
"Ground11","1","Ground","","SPICE","","","","",""
"Ground12","1","Ground","","SPICE","","","","",""
"Ground13","1","Ground","","SPICE","","","","",""
"Ground14","1","Ground","","SPICE","","","","",""
"Ground15","1","Ground","","SPICE","","","","",""
"Ground16","1","Ground","","SPICE","","","","",""
"Ground17","1","Ground","","SPICE","","","","",""
"Ground18","1","Ground","","SPICE","","","","",""
"Ground19","1","Ground","","SPICE","","","","",""
"Ground20","1","Ground","","SPICE","","","","",""
"Ground21","1","Ground","","SPICE","","","","",""
"Ground22","1","Ground","","SPICE","","","","",""
"Ground23","1","Ground","","SPICE","","","","",""
"Ground24","1","Ground","","SPICE","","","","",""
"Ground25","1","Ground","","SPICE","","","","",""
"CONN1","1","JTAG-HEADER","","DIL","","","","",""
"JTAGBSCAN","1","JUMPER-2PTH","","1X02","","","","","JumperBasic 0.1"" spaced jumper. Use with breakaway headers."
"U3","1","LD1117V33C","","TO-220","STMicroelectronics","LD1117V33C","6869767","","LDO Regulator 3.3V 1.3A TO220"
"LED1","1","LED1206","","LED-1206","","","","","LEDsStandard schematic elements and footprints for 5mm, 3mm, 1206, and 0603 sized LEDs. 5mm - Spark Fun Electronics SKU : COM-00529 (and others)"
"MUSB1","1","MiniUsbB","","MINI-USB","","","","",""
"R12","1","RESISTOR1206","0ohm","1206","","","","","ResistorBasic schematic elements and footprints for 0603, 1206, and PTH 1/10th watt (small) resistors."
"R2","1","RESISTOR1206","6.8k","1206","","","","","ResistorBasic schematic elements and footprints for 0603, 1206, and PTH 1/10th watt (small) resistors."
"R7","1","RESISTOR1206","6.8k","1206","","","","","ResistorBasic schematic elements and footprints for 0603, 1206, and PTH 1/10th watt (small) resistors."
"R3","1","RESISTOR1206","15k","1206","","","","","ResistorBasic schematic elements and footprints for 0603, 1206, and PTH 1/10th watt (small) resistors."
"R4","1","RESISTOR1206","22k","1206","","","","","ResistorBasic schematic elements and footprints for 0603, 1206, and PTH 1/10th watt (small) resistors."
"R6","1","RESISTOR1206","39","1206","","","","","ResistorBasic schematic elements and footprints for 0603, 1206, and PTH 1/10th watt (small) resistors."
"R5","1","RESISTOR1206","39R","1206","","","","","ResistorBasic schematic elements and footprints for 0603, 1206, and PTH 1/10th watt (small) resistors."
"R1","1","RESISTOR1206","100k","1206","","","","","ResistorBasic schematic elements and footprints for 0603, 1206, and PTH 1/10th watt (small) resistors."
"R9","1","RESISTOR1206","100k","1206","","","","","ResistorBasic schematic elements and footprints for 0603, 1206, and PTH 1/10th watt (small) resistors."
"R10","1","RESISTOR1206","100k","1206","","","","","ResistorBasic schematic elements and footprints for 0603, 1206, and PTH 1/10th watt (small) resistors."
"R11","1","RESISTOR1206","100k","1206","","","","","ResistorBasic schematic elements and footprints for 0603, 1206, and PTH 1/10th watt (small) resistors."
"SW2","1","ts695","","DIL","","","","",""
"SW3","1","ts695","","DIL","","","","",""
The schematics is here:
G+ album is here:
https://plus.google.com/u/0/photos/110230689089207649183/albums/6056369572177773473
Hope it could help someone...
