Topic: Expand the storage by SD card/USB flash/USB hard drive for Yun & compatible (Read 6828 times) previous topic - next topic
sonnyyu
Recover bricked expanded Yun
turn off
take micro SD out
turn on
Code: [Select]
reset-to-factory-anyway
reboot
after Yun complete started
turn off
put micro SD back
turn on
Code: [Select]
wget -O simplesd.sh https://www.dropbox.com/s/jl4oytptxrb6q5u/simplesd.sh?dl=0 --no-check-certificate
/bin/ash simplesd.sh
sonnyyu
Revert back to boot from internal flash:
Code: [Select]
wget -O reset.sh https://www.dropbox.com/s/4g1yfpnas25cepn/reset.sh?dl=0 --no-check-certificate
Code: [Select]
/bin/ash reset.sh
sonnyyu
Code: [Select]
nano reset.sh
Code: [Select]
/bin/mkdir -p /mnt/mtdblock3
/bin/mount -t jffs2 /dev/mtdblock3 /mnt/mtdblock3
/usr/bin/head -n 9  /mnt/mtdblock3/etc/config/fstab > /tmp/fstab
/bin/mv /tmp/fstab /mnt/mtdblock3/etc/config/
/sbin/reboot
lamiastella
result after running it:
./.gnupg/secring.gpg
./.extroot.md5sum
cfg044d78
root@Arduino:~# Write failed: Broken pipe
Monas-MacBook-Pro:~ mona$ ssh root@192.168.1.148
ssh: connect to host 192.168.1.148 port 22: Host is down
What should I do now?
sonnyyu
./.extroot.md5sum
cfg044d78
192.168.1.148 is wifi's ip address or ethernet address?
after run simplesd.sh the Yun will be back to factory default state, i.e. ethernet port has ip address  from system router DHCP release pool and wifi port has "192.168.240.1". The WIFI  port is at ap for Access Point mode.
sonnyyu
http://www.arduino.cc/en/Tutorial/YunSerialTerminal
Load YunSerialTerminal sketch from IDE file->example->bridge->YunSerialTerminal then
type:
Code: [Select]
ifconfig
to find out ip address.
Luis_Filipe
My Yun Shield not have a SD card.
What is the correct form to expand the space to a USB drive attached to her?
The last Release, please.
Thanks in advance
sonnyyu
Thanks in advance
Yes
zeeHacker
Thanks sonnyyu...First script worked great for me!..Really helped me so I guess I'm the first one to show my appreciation...
zeeHacker
zallesov
Thax for this script. First I've tried just copying commands from here from the code https://www.arduino.cc/en/Tutorial/ExpandingYunDiskSpace
but this way is much easier.
I used
Quote
wget -O expand.sh https://www.dropbox.com/s/x2zhfqr4ssfetz1/expand.sh?dl=0 --no-check-certificate
and it seems to work. Other scripts may too.
Still I had to
Quote
mkfs.ext4 /dev/$driver
and
Quote
mount  /dev/sda1  /mnt/sda1
after reboot.
Roque Campos
I'm using your script as part of an automated installation process and I wonder if there is a way to check in a bash script, if the storage was already expanded, to avoid to execute the process more than one time.
Any help is appreciated.
Thanks
sonnyyu
Thanks
http://www.ibuyopenwrt.com/index.php/11-yun-compatible/expand-the-storage-at-yun/18-expand-the-storage
Code: [Select]
if fdisk -l |grep /dev/sda > /dev/null; then
   echo "Start"
   echo "/dev/sda not found!"
   exit 0
fi
