We have our design project. My circuit uses a pump to produce steam. So when the pump is ob, water will flow and then go to the heater to produce steam. The problem is whenever the pump is on, the lcd display different characters and it only happens when the pump is turn on.
I try disconnecting the pump and there is no problem. I hope you can help in this problem. I tried different solutions I can think off but its not working.
My LCD is the Generic 20x4 LCD and my pump is the one you use in the aquarium.
The pump is probably not the problem, but the way you are driving it probably is. It sounds like you might be driving the pump directly when you you should be using a relay.
Well, I did say "sounds like", but there are relays and there are relays, and some draw more than the 20mA available on an Arduino pin. Yours does not sound as if it was made with Arduino in mind, and the fact that LCD is fine when it is disconnected rather suggests that using that particular relay is a bad idea.
This all assumes that the power supply to Arduino is kosher in the first place. The problem could be there instead, and the relay merely reveals it. In that event, I would suggest you have two problems, both power, one at each end.
