Hi.
I'm working on developing a prototype of ECG and somehow I have multiple errors with my code but does know how to fix it. Note that this is just a part of my code and I just posted the part where it caused problems and the error code lines don't match the program code so be aware.
#include "buttons.h" // "buttonSet" class provides UI structures and methods
#include "constants.h" // all constants are defined here
#include "ECGraphics.h" // local library to interface with LCD
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_TFTLCD.h> // Hardware-specific LCD library
#include <TouchScreen.h> // provides methods for touchscreen interface
#include <TimerOne.h> // provides easy methods to interface with arduino's hardware timer
#include <SD.h> // SD card interface library
ulong lastCmdTime; // used to track time of last command issued
ulong lastMonIndex, lastSpikeIndex, lastBPMIndex; // used to track other periodic occurrences
ulong curStartIndex, recStopIndex; // indexes used for file recording and recalling
volatile ulong TimerIndex; // general timer index
volatile ulong MonIndex; // monitor mode index counter
volatile uint Sample[Max_Samples]; // data array for storing sampled input
uint Period[Periods_to_Avg]; // used to calculate average BPM
uint Baseline = Std_Baseline; // used to track changing baseline voltage
uint Peakheight = Std_Peakheight; // used to track maximum peak over the baseline (R-wave height)
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 360); // set up touchscreen (x & y bounds, resistance)
buttonSet ECGButtons; // array and methods to comminicate with touchscreen elements (buttons)
Point p; // temporary storage for touchscreen coordinates
byte cmd; // command code corresponding to a "button" press
byte CurrentState = LOW; // used to track position on waveform (R-wave = HIGH, between peaks = LOW)
boolean Monitor = false; // flag used to turn on monitor mode (input sampling & waveform display)
boolean Analyze = false; // flag used to enable waveforms analysis; not implemented at this time
boolean Record = false; // flag used to signal recording mode
struct { // structure for settings that are saved to file
byte HRlow, HRhigh; // high & low heart rate critical values
uint fileIndex; // index for current recorded file
boolean Alarms; // flag to turn on/off audible alarms
boolean Filter; // flag to turn on/off digital filter
} Settings = {50,120,1,true,true};
File configFile, dataFile; // File handles for settings, recording / recall
File displayFile, parentDir; // Handles for file manager
char curFileName[12]; // string used to build recorder file name
* Function: File_ShowNext *
* Purpose: Handles the "Next" button press in the File menu *
* Inputs: none *
* Description: *
* Gets the next entry from the current directory structure, *
* displays the file name and file size. Checks if the entry *
* is valid, displays or disables the file action buttons. *
* TO DO: Check if it's a valid file, display more stats. *
void File_ShowNext()
displayFile = parentDir.openNextFile(); // retrieves next entry in file list
if (displayFile) { // if it's not empty (i.e. end of list)
strcpy(curFileName,displayFile.name()); // get the file name
drawTxt(100,70,BLACK,curFileName); // display the file name
if (!displayFile.isDirectory()) { // if it's not a directory (i.e. it's a file)
ECGButtons.enable(Filemgr_Display); // enable the file action buttons
ECGButtons.enable(Filemgr_Delete);
drawNum(100,130,BLACK,displayFile.size()/2); // assume it's a valid file and show number of samples it represents
ECGButtons.disable(Filemgr_Display); // disable the action buttons
displayFile.close(); // close the file handle
drawTxt(100,70,BLACK," "); // blank out the file name
ECGButtons.disable(Filemgr_Delete);
The Error message that I got:
Arduino: 1.5.6-r2 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
PECGM5:41: error: 'file' does not name a type
PECGM5:42: error: 'file' does not name a type
PECGM5.ino: In function 'void File_ShowNext()':
PECGM5:58: error: 'displayFile' was not declared in this scope
PECGM5:58: error: 'parentDir' was not declared in this scope
PECGM5.ino: In function 'void Loop_Buttons(byte)':
PECGM5:165: error: 'parentDir' was not declared in this scope
PECGM5:170: error: 'dataFile' was not declared in this scope
PECGM5:170: error: 'SD' was not declared in this scope
PECGM5.ino: In function 'void Menu_Filemgr()':
PECGM5:342: error: 'parentDir' was not declared in this scope
PECGM5:342: error: 'SD' was not declared in this scope
PECGM5.ino: In function 'boolean Record_PrepFile(uint)':
PECGM5:419: error: 'dataFile' was not declared in this scope
PECGM5:419: error: 'SD' was not declared in this scope
PECGM5:419: error: 'FILE_WRITE' was not declared in this scope
PECGM5.ino: In function 'void Record_Writedata()':
PECGM5:444: error: 'dataFile' was not declared in this scope
PECGM5.ino: In function 'void Settings_Update()':
PECGM5:458: error: 'configFile' was not declared in this scope
PECGM5:458: error: 'SD' was not declared in this scope
PECGM5:458: error: 'FILE_WRITE' was not declared in this scope
PECGM5.ino: In function 'void setup()':
PECGM5:590: error: 'SD' was not declared in this scope
PECGM5:594: error: 'configFile' was not declared in this scope
PECGM5:594: error: 'SD' was not declared in this scope
PECGM5:594: error: 'FILE_READ' was not declared in this scope
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
