I have a sketch found for max7219 8 digits display, to make a stop watch.
but that was created with a chipkit uno32. and used I/O port 38 for press Stud.
My question is that port 38 interchangeable with arduino uno A0???
Project: chipKIT Uno32 Stopwatch
Description: This project describes how to interface a MAX7219 based serial seven segment
LED display to contruct a simple digital stopwatch. A push button is connected to
INT0 pin of chipKIT Uno32 board for start and stop operation
Written by: Raj Bhatt (May 2, 2014)
www.embedded-lab.com
MAX7219 connections:
MAX7219 chipKIT Uno32
VCC ---------------> 5.0V
DIN ---------------> Pin 7
CLK ---------------> Pin 6
LOAD ---------------> Pin 5
GND ---------------> GND
Start/Stop tact switch is connected to INT0 (Pin 38) pin.
This software is licensed under a
Creative Commons Attribution-ShareAlike 3.0.
#include "LedControl.h"
// Pin 7 to Data In, 6 to Clk, 5 to LOAD
LedControl lc=LedControl(7,6,5,1);
int fsec, sec, minute, i, Start;
long previousMillis = 0;
long interval = 100;
// the zero refers to the MAX7219 number, it is zero for 1 chip
lc.shutdown(0,false);// turn off power saving, enables display
lc.setIntensity(0,15);// sets brightness (0~15 possible values)
lc.clearDisplay(0);// clear screen
fsec = 0;
sec = 0;
minute = 0;
Start = 0;
lc.setChar(0, 2,'-',false);
lc.setChar(0, 5,'-',false);
Disp_Data();
attachInterrupt(0, Button_Pressed, FALLING);
if(Start == 1) {
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
fsec = fsec+10;
if(fsec == 100) {
fsec = 0;
sec = sec+1;
if (sec == 60) {
sec = 0;
minute = minute+1;
if(minute == 100) minute = 0;
Disp_Data();
void Button_Pressed(){
if (Start == 1) {
Start = 0;
else if (Start == 0){
Start = 1;
void Disp_Data(){
int ones, tens;
// First display fsec
ones = fsec%10;
tens = (fsec/10)%10;
lc.setDigit(0,1,(byte)tens,false);
lc.setDigit(0,0,(byte)ones,false);
// Now display sec
ones = sec%10;
tens = (sec/10)%10;
lc.setDigit(0,4,(byte)tens,false);
lc.setDigit(0,3,(byte)ones,false);
// Next display mm
ones = minute%10;
tens = (minute/10)%10;
lc.setDigit(0,7,(byte)tens,false);
lc.setDigit(0,6,(byte)ones,false);
I can with the uno compilleren this program, so it would have to work further.
But is port 38 te same als A0 on uno
