Thanks for the response, but I'm still having trouble.
If you have declared the recPulse method static
I know how to declare an individual variable as static, but I've not tried this with a method before, and when I do it just seems to generate more errors. As you can see from the sketch I've actually managed to work around the problem by setting up the interrupt in the sketch and causing it to call a function from the library, but I'd still like to know how to do this properly!
I've attached a stripped down, but working version of the files (working except for the compile error!)
Here's the full .h file...
#ifndef HallPulseCounter_h // These lines (together with the #endif at the end of the file) prevent
#define HallPulseCounter_h // any problems occuring if this library should be included twice.
extern "C" {
#include <string.h>
#include <stdlib.h> // needed for 'free'
#include "WProgram.h" // needed for 'Serial'
#include <avr/pgmspace.h> // Needed for PROGMAN stuff
#include <ProgmemConst.h> // Global progmem constants
const int HALL_ARRAY_SIZE=6; // Size of array that holds pulse timestamps
const int MAX_AGE=6000; // Maximum age of any recorded pulse.
// If defined, data will be writen to a logfile as well as displayed on screen
//#define DEBUG_LOG
class HallPulseCounter
public:
HallPulseCounter(); // Constructor
void begin(int pin); // Set the pin that the probe is connected to
//int getFreq(void); // Return the pulse frequency in RPM
void recPulse(); // Record the moment a pulse occurs
private:
// Member variables
char * _info; // Temporary storage used for holding strings (normally error messages)
// for logging to SD card.
unsigned long _pulse[HALL_ARRAY_SIZE]; // array of timestamps of most recent pulses.
#endif
And the full .cpp file....
extern "C" {
#include <string.h>
#include "HallPulseCounter.h" // header for this library
#ifdef DEBUG_LOG
SingLog2 *logComp = SingLog2::GetLogger(); // Global (to this class) singleton logger.
#endif
Constructor
HallPulseCounter::HallPulseCounter()
_info = gMedBuff; // link the local info buffer to the global buffer (defined in ProgmemConst.cpp)
Set the pin that the probe is connected to.
void HallPulseCounter::begin(int pin)
int interrupt =0;
// define the pin as an INPUT
pinMode(pin, INPUT);
// attach the appropriate interrupt
attachInterrupt(interrupt,recPulse,FALLING);
//attachInterrupt(interrupt,HallPulseCounter::recPulse,FALLING);
//attachInterrupt(interrupt,HallPulseCounter.recPulse,FALLING);
//attachInterrupt(interrupt,HallPulseCounter->recPulse,FALLING);
//attachInterrupt(interrupt,this->recPulse,FALLING);
Record the moment that a pulse was detected by the hall probe
void HallPulseCounter::recPulse()
// Load the timestamp for this pulse into the top of the array.
_pulse[0] = millis();
And sketch to test....
#include <Wire.h> // Library to control I2C comunications
#include <HallPulseCounter.h> // Rev-counter library based on hall-effect probe.
int rpm = 0;
HallPulseCounter cadence1;
Serial.begin(115200); // start serial communication at 9600bps
Serial.println("##################################################################");
Serial.println("#################### START ###############################");
cadence1.begin(3); // Connect hall sensor to pin 3 (interrupt 1)
attachInterrupt(1,recordPulse,FALLING);
//rpm=cadence1.getFreq();
Serial.print("rpm <"); Serial.print(rpm); Serial.println("> (revs per min)");
delay(100); // wait for half a second
void recordPulse()
cadence1.recPulse();
