Arduino Forum
Using Arduino => Motors, Mechanics, and Power => Topic started by: Drake on Jan 20, 2013, 09:48 pm
Title: Controlling a simple toy car with Arduino Mini 05 or similar.
Post by: Drake on Jan 20, 2013, 09:48 pm
Hi, I would like to make a experiment with a toy car, the car have a 130 Mabuchi motor and are using a coil system for the steering.
I need to find a way to control the coil and how to make the power go in different directions to steer left and right and how to control the motor.
Where to start?
I am searching an example of controlling a coil with Arduino
Any help is appreciated.
Title: Re: Controlling a simple toy car with Arduino Mini 05 or similar.
Post by: johnwasser on Jan 21, 2013, 12:29 am
The device you need to control the force & direction of a solenoid is the same device you need to control the speed & direction of a DC motor.  It's an H-Bridge.  For a full-size Arduino like an UNO you would typically use a Motor Control Shield.  For an Arduino Mini you can't use a standard shield so you should probably look for a breakout board.
You need to determine the voltage and current requirements of your devices so you can pick an appropriate H-Bridge.
