Topic: Change the Arduíno (Read 538 times) previous topic - next topic
edurocha
Can I download this software, modify the source code and create my own version? There's some legal restriction?
artisticforge
Why would you want to do that?
Important Things to Consider
Arduino IDE is written in Java.
There are several different software License in the code.
You would have to read each software license.
pert
Sure. Here's the source code:
https://github.com/arduino/Arduino
Here's the build instructions:
https://github.com/arduino/Arduino/wiki/Building-Arduino
The general license for the Arduino IDE code is GPL v2.0, see:
https://github.com/arduino/Arduino/blob/master/license.txt
but as artisticforge said, there are different licenses for other components and you'd need to evaluate them as well. If you're just wanting to tinker around with the IDE code for your own personal use then you have nothing to worry about. If you want to distribute the code you will need to make sure to comply with the licenses.
flounder
Also, if you want to submit what you've done as a new feature for everyone, you need to create a license for your code, e.g., GPL v2.0, plus conform to the procedures for submitting a new feature.
