I'm trying to get the following code to work for me:
#include <SPI.h>
#include <Wire.h>
#include <Ethernet.h>
//#include <UIPEthernet.h>
#include <DHT.h>
#include <stdio.h>
dht DHT;
#define DHT22_PIN 2
float combined_temp_C;
float combined_temp_F; //create a new variable
byte TempHi; // Variable hold data high byte
byte TempLo; // Variable hold data low byte
boolean P_N; // Bit flag for Positive and Negative
boolean P_N112;
boolean P_N212;
unsigned int Decimal; // Variable hold decimal value
char * strTempC = NULL;
char * strTempF = NULL;
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x4E, 0x10 }; // MAC address 84.85.88.16.0.36
byte ip[] = { 192, 168, 1, 203 }; // ip-address, please change to fit your network
byte mydns[] = { 192, 168, 1, 1 };
byte gateway[] = { 192, 168, 1, 1 };
byte subnet[] = { 255,255,255,0 };
EthernetServer server(80);
static char output[300] = "";
//ethernet
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
char headerHTML[] = "HTTP/1.1 200 OK\r\n"
"Content-Type: text/html\r\n"
"Connection: close\r\n"
"Refresh: 5\r\n"
"\r\n"
"<!DOCTYPE HTML>"
"<Title>RBBS Server</Title>"
"<html>";
char footerHTML[] = "</html>" ;
char * TimeElapsed() { // Was Home Page
long t = millis() / 1000;
word h = t / 3600;
byte m = (t / 60) % 60;
byte s = t % 60;
sprintf(output, "<h1>%d%d:%d%d:%d%d</h1>" , h/10, h%10, m/10, m%10, s/10, s%10);
return output;
void sendTempToNetwork(EthernetClient myClient)
// now humidity / temp sensor
int chk = DHT.read22(DHT22_PIN);
myClient.print("Humidity=");
myClient.print(DHT.humidity,0);
myClient.print("%");
myClient.print("
myClient.print("Temperature=");
myClient.print(DHT.temperature, 0);
myClient.write(" ");
myClient.print("C");
myClient.print("
myClient.print("Dewpoint=");
myClient.print(dewPoint(DHT.temperature,DHT.humidity), 0);
myClient.print("
void sendAnalogToNetwork(EthernetClient myClient)
// output the value of each analog input pin for good measure
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
myClient.print("analog input ");
myClient.print(analogChannel);
myClient.print(" is ");
myClient.print(sensorReading);
myClient.println("
* Main Loop
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.print(headerHTML);
// now send the stuff we want
client.print(TimeElapsed()); // your old code here
// do some more stuff
sendTempToNetwork(client);
sendAnalogToNetwork(client);
// were done sending so now send the footer to close the page
client.println(footerHTML);
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
delay(2000);
void Cal_Temp()
if (TempHi&0x80) // If bit7 of the TempHi is HIGH then the temperature is negative
P_N = 0;
else // Else the temperature is positive
P_N = 1;
TempHi = TempHi & 0x7F; // Remove sign
TempLo = TempLo & 0xF0; // Filter out last nibble
TempLo = TempLo >>4; // Shift right 4 times
Decimal = TempLo;
Decimal = Decimal * 625; // Each bit = 0.0625 degree C
combined_temp_C= TempHi + TempLo*.0625;
combined_temp_F = combined_temp_C*1.8+32;
sprintf(strTempC, "%f", combined_temp_C);
sprintf(strTempF, "%f", combined_temp_F);
////Celsius to Kelvin conversion
//double Kelvin(double celsius)
// return celsius + 273.15;
// dewPoint function NOAA
// reference: http://wahiduddin.net/calc/density_algorithms.htm
double dewPoint(double celsius, double humidity)
double A0= 373.15/(273.15 + celsius);
double SUM = -7.90298 * (A0-1);
SUM += 5.02808 * log10(A0);
SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
SUM += log10(1013.246);
double VP = pow(10, SUM-3) * humidity;
double T = log(VP/0.61078); // temp var
return (241.88 * T) / (17.558-T);
// delta max = 0.6544 wrt dewPoint()
// 5x faster than dewPoint()
// reference: http://en.wikipedia.org/wiki/Dew_point
double dewPointFast(double celsius, double humidity)
double a = 17.271;
double b = 237.7;
double temp = (a * celsius) / (b + celsius) + log(humidity/100);
double Td = (b * temp) / (a - temp);
return Td;
However I'm getting a number of errors:
sketch_nov26b.ino:7:1: error: ‘dht’ does not name a type
sketch_nov26b.ino: In function ‘void sendTempToNetwork(EthernetClient)’:
sketch_nov26b.ino:56:18: error: expected primary-expression before ‘.’ token
sketch_nov26b.ino:58:23: error: expected primary-expression before ‘.’ token
sketch_nov26b.ino:62:23: error: expected primary-expression before ‘.’ token
sketch_nov26b.ino:67:32: error: expected primary-expression before ‘.’ token
sketch_nov26b.ino:67:48: error: expected primary-expression before ‘.’ token
If you can help I'd appreciate it. Thanks
DWW
Code was taken from:
