Hi
I'm trying to make a pulse sequence generator. The user should be able to change some variables (for controlling frequency, pulse width, etc.) within the code without having to reprogram the board every time a variable changes. I realize that this can be done through serial monitor, but I need a graphical user interface that looks like this:
How do I make something like this and how do I interface it with Arduino?
By the way, I'm new to Arduino. I have some background in C and I have never done anything graphical.
Thank you in advance.
I presume your intention is that the GUI will be on your PC and, if so, you need to get advice about that from a Forum that deals with PC programming. If you use Windows (I don't) the various Visual XXX programming languages should make it easy to create a GUI.
As far as sending data to the Arduino is concerned have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
The technique in the 3rd example will be the most reliable.
You can send data in a compatible format with code like this. It will be possible to create equivalent code in any PC programming language.
