Topic: ionisiation? (Read 7401 times) previous topic - next topic
Joes
hi there
i have been making a control unit for gas/oil boiler i would like to try and get the ionisation probe to work with my aduino. i didnt know if anyone had tried this or has got any information on someting like this?
thanks
robtillaart
Can you share some pictures and/or code sofar (to get a better understanding of what you want to accomplish?
Rob Tillaart
Joes
just found this link just a bit of general info about it. i havent gor any pics just a piece of ceramic with a metal bar going through it which is in the flame and th ceramic insulates it from the chassis
didnt know if anybody has played with this is the arduino world
http://www.petervis.com/electronics%20guides/polonium%20detector/ionisation%20chamber.html
Grumpy_Mike
Assuming you stick this in a flame, it will act as a conductor when it is in a flame and an insulator out of it.
So just put it between the input and ground and have an external pull up resistor of 1K.
It should work fine in a digital input.
Joes
ok cool
just to clarify where exactly should i put the resistor?
thanks
Grumpy_Mike
From the input pin to +5V.
Joes
ok thanks will have to have a play with that when i get time
Joes
hi again
i have made bit of a rig up and ran your theory above and i couldnt seem to get it to work at all. i think there is a bit more to it than i originally thought ?
Grumpy_Mike
A flame consists of ionized gas, if two conductors are placed in it then current will flow.
Many years ago I put an audio signal through a flame simply by placing it in series with the speaker connection.
If you are not getting anything from it try and measure the resistance of the probe and sheath, it might me made of some resistive materiel so that it works on a higher voltage.
kunkmiester
There will also be issues with the conductivity of the probe and flame, and your 1K resistor might be a bit much, if the probe's resistance is high enough.  Measure the resistance, and use Ohm's law to find the power drawn.  You want to make sure the power is below the max for the arduino, but high enough to register.  If the voltage is dropping too much to register, or the current is too high and tripping protection or something, it wouldn't work.
MarkT
Quick google suggests 100Mohms is a good starting point...  A flame is not that good a conductor!
Also found this fascinating page: http://www.sparkbangbuzz.com/flame-amp/flameamp.htm
Joes
hi there
i have been playing with different resistances. im up in the 2000k to get it to work on my test rig on my finished product i might be able to get it lower than that but i was wandering is it ok to use these sorts of resistances?
Grumpy_Mike
Well it won't do any harm but it might be a bit suceptable to noise.
You can try a higher voltage with a 5.1V zenner to protect the input.
Joes
what switch the live instead of the 0v?
Grumpy_Mike
