Topic: nRF24L01 + Joystick Shield (Read 504 times) previous topic - next topic
YusufBas
Hello guys i use nrf24l01 with joystick shield but  if the switch is on 5v my nrf stops working, but joystick on the shield uses 5v, I saw so many guys using it with switch on 5v with no problem, but my nrf stops working. Please help. Or i will be have cut the vcc header of the nrf and solder a wire between vcc and  3v3 on arduino.
Whandall
#1
May 21, 2017, 09:59 am Last Edit: May 21, 2017, 10:18 am by Whandall
If it is the funduino shield, The NRF is always supplied with 3.3V.
The other NRF pins are 5V tolerant, so that should not be a problem.
Ah, this is obviously some strange usage of the word 'safe' that I wasn't previously aware of. (D.Adams)
Whandall
I now own such a Funduino Joystick Shield V1.A and did some further tests.
The power supply for the NRF24L01+ only worked for transmission (2MHz 0dB),
even with a 10µF added to the power pins.
Adding an AMS1117 brought the NRF24L01+ to full operation.
