Topic: Arduino Zero Sercom1 SPI Slave (Read 7624 times) previous topic - next topic
It's really helpful.
Hi hhbcd,
On my Windows based machine the register definitions are located at:
In the "include" directory, there are two further directories: "instance" and "component".
Instance contains the register definitions for each peripheral instance, for example tcc0.h, tcc1.h, etc...
Component contains the structures and definitions for the peripheral's register bitfields, for example tcc.h.
  • Changed DOPO to 0, to select PAD0 for MISO (corresponding to PA12:MISO on the board)
Hi Maverick123,
DOPO should be set to 0x3, which corresponds to PAD[0]: MISO , PAD[3]: SCK, PAD[1]: SS. The other option (0x0) will not select the correct SCK and SS pads.
More info can be found on page 438 of the complete datasheet.
