Hello people,
I'm posting my first library. It's a library for the MMA7361 accelerometer. I hope this is the correct way to share libraries
Since no library was available I believed posting mine would help some people.
I'm always open for suggestions since this is my first library I expect it not to be perfect.
available for download http://rapidshare.com/files/435429883/AcceleroMMA7361.zip
header file
* acceleroMMA7361.h - Library for retrieving data from the MMA7361 accelerometer. Only tested *
* with Duemilanove *
* Following functions need improving. I asumed the output to be linear (it is nearly linear but *
* not really). I also asumed the Arduino input to be scaled 0-5V *
* begin variables *
* -int sleepPin: number indicating to which pin the sleep port is attached. DIGITAL OUT *
* -int selfTestPin: number indicating to which pin the selftest port is attached.DIGITAL OUT *
* -int zeroGPin: number indicating to which pin the ZeroGpin is connected to. DIGITAL IN *
* -int xPin: number indicating to which pin the x-axis pin is connected to. ANALOG IN *
* -int yPin: number indicating to which pin the y-axis pin is connected to. ANALOG IN *
* -int zPin: number indicating to which pin the z-axis pin is connected to. ANALOG IN *
* -int offset: array indicating the G offset on the x,y and z-axis *
* Functions currently present: *
* -getXRaw(): Instantly returns the raw data from the X-axis analog I/O port of the Arduino as *
* a double. WARNING! OFFSET HAS NO INFLUENCE *
* -getYRaw(): Instantly returns the raw data from the Y-axis analog I/O port of the Arduino as *
* -getZRaw(): Instantly returns the raw data from the Z-axis analog I/O port of the Arduino as *
* -getXVolt(): Instantly returns the voltage in miliVolts from the X-axis analog I/O port of *
* the Arduino as a double. WARNING! OFFSET HAS NO INFLUENCE *
* -getYVolt(): Instantly returns the voltage in miliVolts from the Y-axis analog I/O port of *
* -getZVolt(): Instantly returns the voltage in miliVolts from the Z-axis analog I/O port of *
* -getXAccel(): Instantly returns the acceleration of the X-axis as a double (1G = 100.00) *
* -getYAccel(): Instantly returns the acceleration of the Y-axis as a double (1G = 100.00) *
* -getXAccel(): Instantly returns the acceleration of the Z-axis as a double (1G = 100.00) *
* Revision History: *
* Version 0.1: get raw values *
* Version 0.2: get voltages and G forces *
* Created by Jef Neefs: Suggestions, questions or comments please contact me *
* - mail: neefsj at gmail dot com *
* - skype: studioj *
#ifndef AcceleroMMA7361_h
#define AcceleroMMA7361_h
#include <WProgram.h>
class AcceleroMMA7361
public:
AcceleroMMA7361();
void begin(int sleepPin, int selfTestPin, int zeroGPin, int xPin, int yPin, int zPin, int xOffset, int yOffset, int zOffset);
double getXRaw();
double getYRaw();
double getZRaw();
double getXVolt();
double getYVolt();
double getZVolt();
double getXAccel();
double getYAccel();
double getZAccel();
double getTotalVector();
private:
long _mapMMA7361V(int value);
long _mapMMA7361G(int value);
int _sleepPin;
int _selfTestPin;
int _zeroGPin;
int _xPin;
int _yPin;
int _zPin;
int _xOffset;
int _yOffset;
int _zOffset;
#endif
cpp file
comment header as in h file is left away
#include <AcceleroMMA7361.h>
AcceleroMMA7361::AcceleroMMA7361()
void AcceleroMMA7361::begin(int sleepPin, int selfTestPin, int zeroGPin, int xPin, int yPin, int zPin, int xOffset, int yOffset, int zOffset)
pinMode(sleepPin, OUTPUT);
pinMode(selfTestPin, OUTPUT);
pinMode(zeroGPin, INPUT);
pinMode(xPin, INPUT);
pinMode(yPin, INPUT);
pinMode(zPin, INPUT);
digitalWrite(sleepPin,HIGH);
digitalWrite(selfTestPin,LOW);
_sleepPin = sleepPin;
_selfTestPin = selfTestPin;
_zeroGPin = zeroGPin;
_xPin = xPin;
_yPin = yPin;
_zPin = zPin;
_xOffset = xOffset;
_yOffset = yOffset;
_zOffset = zOffset;
double AcceleroMMA7361::getXRaw()
return analogRead(_xPin);
double AcceleroMMA7361::getYRaw()
return analogRead(_yPin);
double AcceleroMMA7361::getZRaw()
return analogRead(_zPin);
double AcceleroMMA7361::getXVolt()
return _mapMMA7361V(analogRead(_xPin));
double AcceleroMMA7361::getYVolt()
return _mapMMA7361V(analogRead(_yPin));
double AcceleroMMA7361::getZVolt()
return _mapMMA7361V(analogRead(_zPin));
double AcceleroMMA7361::getXAccel()
return _mapMMA7361G(analogRead(_xPin))+ _xOffset;
double AcceleroMMA7361::getYAccel()
return _mapMMA7361G(analogRead(_yPin)) + _yOffset;
double AcceleroMMA7361::getZAccel()
return _mapMMA7361G(analogRead(_zPin)) + _zOffset;
long AcceleroMMA7361::_mapMMA7361V(int value)
return map(value,0,1024,0,5000);
long AcceleroMMA7361::_mapMMA7361G(int value)
return map(value,0,1024,-800,1600);
