arduinoadrian:
I think the weight mass method you are proposing is good; but you will need to set a spring or something to make the thing retract when the weight goes up and calibrating that spring will be a difficult task. The floaters move freely. Floaters have been used forever to meassure liquids specific gravities and that maybe the reason why.
Anyway if the weight (which is acctually a floater too) can be attached to the weighting system without affecting the meassurement then maybe it is another solution to the same problem.
A basic rule in measurements is that the meassuring system used should not affect the system being measured.
I'm not sure you understood my method. I said a heavy weight thus submerged. Something like steel or aluminum (is that alright in drinks?). You need not pull it down with springs. I don't think a floater can be easily attached to a weighing system. It's already balanced in its forces and designed to do so.
I don't get it. How wil the liquid specific gavity will affect your weight? Oh the other hand if you are weighting the liquid why do you need the weight? I understand the liquid weight changes; but the weight pounds will change with the liquid specfic gravity.
Sorry, you are right I don't understand the method.
liudr:
What range of specific gravity are you trying to measure? I am thinking about lowering a heavy object into the liquid (not touching the ground) and having a force gauge hold the string. Depending on specific gravity the force gauge reads different values.
Your weight does not touch the ground and you need to hold it with a string. A heavy object will not be affected by changes in the liquid voyancy which is what's being measured. Without the string it will sink. Once the object especific weight surpasses the espeific weight of the liquid it sinks. To do that the especific weights of the liquid and the object must be similar and that's exactly what they do with the gravity measuring bulbs when filling them with pellets of heavier metals. They are trying to match both to make the object float at a certain depth/ Soemting like subs. Please don't take me wrong we are just brainstorming here and we all learn from each other. That's all. Thanks
The heavy object is submerged but not touching the bottom of the container. That I hope is clear enough for everyone.
that's under the impression the object is sitting on the bottom or just not understanding what buoyancy force means? If liquid density (specific gravity) changes, buoyancy force changes. You should check some reference before "brainstorming". My understand of the word is that you think of some random stuff but still they have to be correct. Otherwise it's hard to differentiate it from bullshitting.
Bullshittinmg is posting without reading or understanding. Read my post before posting and yu'll see I mentioned exactly that.
By the way no one here voted fo your load cell anyway. No one liked it; don't take it pesonal, it happens...
arduinoadrian:
Please stop spreading your misunderstanding about "voyancy". It's not even a word. No one needs to know that you don't know. Don't pretend to know what you don't. We see plenty that everyday, won't make you special. Who said I care about a vote? Did someone call for a vote or you just did that in your head?
arduinoadrian:
Didn't realise it was a poll. It's a perfectly feasible solution, and the only thing I don't much like about it is that it seems to require moving parts which I think would be problematic in a hygienic environment. And just about all the other solutions being suggested suffer from a similar problem.
You don't even know how buoyancy force changes with specific gravity and you are talking it and giving advice, so feel embarrassed and go google it. I don't even know you so how am I making it personal? Like by saying your name? I don't know that, just some @$$&9@& pretending to know some science. That is as personal as I may get. I don't even bother that much. All I want is for nonsense to stop. You happen to be that person spreading it. I can't stand it. You want to take it personal then it is your own problem. I can see that in a separate post you like "brainstorming" and tend to fight back with others unfavorable comments. Why don't you humble yourself with some wiki reading about buoyancy force and correct some spellings at the time? Too old to take unfavorable comments or too young to be polite?
PeterH:
Peter,
Not a moving part. You lower a weight into the liquid and tie the string to a force gauge. The weight balances with gravity, buoyancy force and string. If specific gravity increases then buoyancy force increases and string force decreases. The force gauge reads it as a decrease. The weight stays immobile, no moving parts. We do this lab in intro physics labs to determine salt water density with a 0.1g accuracy balance. The result is not bad. With a floating meter you can read it but salt starts gathering on it and the reading is affected. I imagine similar effects with floaters inside the liquid.
Well, this other guy is doing a vote all by himself, apparently that is what he considers as a vote. I must have not learned my English well enough. Sounds like communist vote. One person votes
People can read the posts and they will realize you started the arguments when I contradicted your opinion. That's taking it pesonal and you keep doing it over and over. You did said "brainstorming" I mentioned was bs. It was you. I even said that your load cell thing was a good thing then; but like with anything else there were problems with the hook up string. You were also the subject of the argument there. It has been you alll the time. Now you are calling me old, young and a bunch of other things that just make me laugh, just because I desagreed with your opininon. Isn't that taking it pesonal? Remember stay proffessional and argue with science not with insults they aren't going to make you prevail. When I said No one voted I meant no one mentioned your load cell, except me by the way...
Buoyancy ("vouyancy" hahaha thanks fo the clarification on the spelling) is not something that difficult to understand, that's why its taught in elementay I guess, so don't be so possessive about your knowledge on that. Take it easy we all learn with all this.
liudr:
I assumed that you would be dipping it rather than leaving it immersed, but you know what they say about people who assume. I thought that would be the only sensible way to get rid of the unpredictable variable buoyancy effects from bubbles collecting on the wetted surfaces.
PeterH:
I'm glad everyone's as passionate about SG readings as I am.
On the other hand I'm now thinking about using a sampling method. The advantage of this is that I can keep everything out of the fermenting bin which will help in sanitizing the whole thing and I'll also be able to move it all to another bin without quite so much effort. The disadvantage is it it will have a pump and added complexity which will make infection more likely but since it's modular I should just be able to submerge the whole thing into sanitizing fluid. Aquarium pumps are used in homebrewing a fair bit so they can't be that bad, you can get those ones that just squeeze the tube whatever they're called and they should be simple to clean.
My plan would be to have the pump suck up the wash for a while and which would be filling a container until it is full and then the rest (including yeast head) will all wash down the side and run back into the bin. Then I would just measure the weight of the container. This way the mass would be constant and I wouldn't have to worry about the bubbles or variation in the liquid volume.
My only concerns are that weighing the liquid might be tricky while trying to keep the whole thing sealed (to prevent contamination) and I'd have to have some kind of valve to release the liquid from the container afterwards. I was also concerned about sediment settling and screwing up my measurements but I figure I can program some kind of cleaning routine after a measurement and have the pump blast it all away by opening the valve and rinsing it all out with. There's also the concern of having the measurements disturbing the fermentation while it's conditioning. It won't be a problem during the early stages but later on I'll have to limit the readings to something like twice a day and try to minimize how much it disturbs the sediment that's already settled.
edit
Come to think of it, couldn't I just make the container tall and thin and bring the pressure sensor back into play? That way I wouldn't need to worry about isolating the container for the purposes of weighting it and I just use some kind of pinch valve to close the bottom since I wouldn't have to be thinking about balancing it on another sensor or anything.
Weighing the liquid itself is a good method; but in your case (as you mentioned) there are several inconveniencies. On the other hand, to use this method in a reliable and consistent way you need to be very precise in the volume of liquid you are weighing. To keep the volume nearly constant everytime the measurement is done by pumping can be difficult to achieve. In the "thin and tall column" there will also be evaporation reducing the amount of liquid and therefore its weight affecting the specific gravity calculations. You won't be able to determine if the change in weight is due to density change or evaporation. The main problem is that several factors not only specific gravity changes are affecting the System under measurement. That's why this is normally done by taking a known volume sample of the liquid and weighing it or dipping in an specific gravity measuring bulb and observing how much it sinks. These two methods remove all other influencing variables. In the case of the floating device that is achieved by placing the scale in the device itself.
I get what you mean but I plan to make sure I always use the same volume by pumping more than the container can hold so the excess overspills. By example I mean, if you get a 1 litre container and pour 2 litres into it, there's still only going to be 1 litre in the container. By taking the measurement straight away and then flushing it should that not solve the issue of having to have exactly the same volume each time and by allowing a few seconds for it to settle and then taking the measurement straight away would that not prevent evaporation from having a noticeable influence? It might take some calibration to set up but I would think it was only required once.
The way you are expalining it now might work. Looks very reasonable to me if you keep volume changes.
I've been thinking there might be a correlation between the liquid specific gravity and its conductivity... After all, changes in the liquid density are related to changes in its contents; that is its chemical composition. Even if the relationship is not linear the mathematical equation can be obtained (not hard to do I've done it several times) and linearize the thing in the soft to extrapolate the specific gravity from the measured conductivity. You can to research that. Probably someone tried that already. If you can't find nothing some experimentation may yield some measurement values we can work with. Conductivity measurements are way easier to perform and it can be monitored continuosly. I have doubts about the cleanliness of the eletrodes ,etc to be suitable for your particular case though.
What about liquid opacity or its ability to transmit light. Does it change during the brewing? I've never done any brewing; but from the experience of consuming its product, I guess so..,
If you set a glass tube parallel to the main container similar to a level indication tube and then an optical system with an LED and a Light depending resistor using infrarred maybe you can meassure the opacity of the liquid and also correlate it with specific gravity. Again taking measurements we can find the equation correlating them and extrapolate specific gravity from the light transmission measurement. This will leave the electrodes corrosion and cleeanliness problem out that the conductivity method will create. The tube just need to be long enough for the sensor to be attached to it and have a glass window for the light to pass through . In that way you won't have ambient light affecting your brewing. It wil require maintenace (cleaning) from time to time; but that's minimal.
You will need to set up the system and run a test brewing where you log in the PIR sensor readings and meassure specific gravity with a real bulb from time to time. You post here the samples and we will find the equation. It may not matter that much if the opacity changes with other variables as the mathematical equation found will remove them out. It will correlate just the variables measured. Several trials maybe required.
I like your thinking but it wouldn't work I'm afraid. There can be any amount of gunk in there and opaqueness can vary wildly, if you make a sugar was it can be all the way up to 1.090 (strong pre-ferment) and yet be almost as clear as water, while if you were using a coffee malt it would be really dark down at 0.90 (fermentation complete).
Conductivity:
I'm not so sure about this one but I have heard it mentioned before. I saw a discussion which went into greater lengths about using capacitance as the indicator, treating the wash as the dielectric. It was ultimately determined that the ingredients were so variable, with so many different types of crap making up the mash, that it couldn't be done in any kind of predictable way. I suppose it's likely that conductivity might go the same way.
I'm sure there must be some way of just dropping a probe into the wash to determine the SG but buggered if I know what it is. I remember something like a Kickstarter project to create a beer computer and they were going to release a cheaper model and then a more expensive model later on that would be able to read the SG and it would just be this little green box. They didn't give anything away about they planned to take the reading. I've just been googling it now and I can't find it.
The light meassuring thing can be zeroed at the begining depending on the original color of the liquid. On the other hand the fact that a human can't detect differences it does not necessarily mean the meassuring system can't also. For example CO2 is transparent to humans; but there are CO2 detectors working on that principle outthere. They use a specific infrared wavelenght that's absorbed by CO2 only. I guess the CO2 content of the liquid increases with time as the yeast works. ???. maybe you can monitor CO2 content with such sensor which I belive is used in fire alarms and smoke detector. I think this is not so hard to try compared with other methods suggested like my floaters for example. I would give a simple trial and see what happens. We maybe surprised by the results...
Check densitometers and spectrophotometers.
