beste Forumleden,
ben bezig om een tutorialtje te volgen op een website. ik ben bezig om een wifi server te maken met op de SD kaart op dit moment nog een klein HTM filetje.
nu is het laden van de server super langzaam en kan niet ontdekken waar het vandaan komt.
misschien hebben jullie een idee.
met vriendelijke groet,
jeroen
Program: eth_websrv_SD
Description: Arduino web server that serves up a basic web
page. The web page is stored on the SD card.
Hardware: Arduino Uno and official Arduino Ethernet
shield. Should work with other Arduinos and
compatible Ethernet shields.
2Gb micro SD card formatted FAT16
Software: Developed using Arduino 1.0.3 software
Should be compatible with Arduino 1.0 +
SD card contains web page called index.htm
References: - WebServer example by David A. Mellis and
modified by Tom Igoe
- SD card examples by David A. Mellis and
Tom Igoe
- Ethernet library documentation:
http://arduino.cc/en/Reference/Ethernet
- SD Card library documentation:
http://arduino.cc/en/Reference/SD
Date: 10 January 2013
Author: W.A. Smith, http://startingelectronics.org
#include <SPI.h>
#include <WiFi.h>
#include <SD.h>
// MAC address from Ethernet shield sticker under board
char ssid[] = "————-"; // your network SSID (name)
char pass[] = "—————"; // your network password
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
File webFile;
Serial.begin(9600); // for debugging
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
while (true); // don't continue
String fv = WiFi.firmwareVersion();
if (fv != "1.1.0") {
Serial.println("Please upgrade the firmware");
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to Network named: ");
Serial.println(ssid); // print the network name (SSID);
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
server.begin(); // start the web server on port 80
printWifiStatus(); // you're connected now, so print out the status
// initialize SD card
Serial.println("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
Serial.println("SUCCESS - SD card initialized.");
// check for index.htm file
if (!SD.exists("index.htm")) {
Serial.println("ERROR - Can't find index.htm file!");
return; // can't find index file
Serial.println("SUCCESS - Found index.htm file.");
WiFiClient client = server.available(); // try to get client
if (client) { // got client?
int clientCount = 0;
boolean currentLineIsBlank = true;
Serial.println("new client"); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
// last line of client request is blank and ends with \n
// respond to client only after last line received
Serial.write(c);
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
// send web page
webFile = SD.open("index.htm"); // open web page file
if (webFile) {
while(webFile.available()) {
client.write(webFile.read()); // send web page to clien
webFile.close();
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
// print where to go in a browser:
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
