Hello, I can provide sample code for naked si1143 chip. I made breakout board and it's available on ebay just search for si1143, go there for connection circuit (in images).
I don't have time to write library for Arduino, but communications are really simple, I will post example.
You need to make si1143.h
#ifndef SI1143_h
#define SI1143_h
#define IR_ADDRESS 0x5A
// register addresses
#define PART_ID 0x00
#define REV_ID 0x01
#define SEQ_ID 0x02 //Si114x-A11 (MAJOR_SEQ=1, MINOR_SEQ=1)
#define INT_CFG 0x03
#define IRQ_ENABLE 0x04
#define IRQ_MODE1 0x05
#define IRQ_MODE2 0x06
#define HW_KEY 0x07
#define MEAS_RATE 0x08
#define ALS_RATE 0x09
#define PS_RATE 0x0A
#define ALS_LOW_TH0 0x0B
#define ALS_LOW_TH1 0x0C
#define ALS_HI_TH0 0x0D
#define ALS_HI_TH1 0x0E
#define PS_LED21 0x0F
#define PS_LED3 0x10
#define PS1_TH0 0x11
#define PS1_TH1 0x12
#define PS2_TH0 0x13
#define PS2_TH1 0x14
#define PS3_TH0 0x15
#define PS3_TH1 0x16
#define PARAM_WR 0x17
#define COMMAND 0x18
#define RESPONSE 0x20
#define IRQ_STATUS 0x21
#define ALS_VIS_DATA0 0x22
#define ALS_VIS_DATA1 0x23
#define ALS_IR_DATA0 0x24
#define ALS_IR_DATA1 0x25
#define PS1_DATA0 0x26
#define PS1_DATA1 0x27
#define PS2_DATA0 0x28
#define PS2_DATA1 0x29
#define PS3_DATA0 0x2A
#define PS3_DATA1 0x2B
#define AUX_DATA0 0x2C
#define AUX_DATA1 0x2D
#define PARAM_RD 0x2E
#define CHIP_STAT 0x30
#define ANA_IN_KEY 0x3B
// ram addresses
#define I2C_ADDR 0x00
#define CHLIST 0x01
#define PSLED12_SELECT 0x02
#define PSLED3_SELECT 0x03
#define PS_ENCODING 0x05
#define ALS_ENCODING 0x06
#define PS1_ADCMUX 0x07
#define PS2_ADCMUX 0x08
#define PS3_ADCMUX 0x09
#define PS_ADC_COUNTER 0x0A
#define PS_ADC_GAIN 0x0B
#define PS_ADC_MISC 0x0C
#define ALS_IR_ADCMUX 0x0E
#define AUX_ADCMUX 0x0F
#define ALS_VIS_ADC_COUNTER 0x10
#define ALS_VIS_ADC_GAIN 0x11
#define ALS_VIS_ADC_MISC 0x12
#define ALS_HYST 0x16
#define PS_HYST 0x17
#define PS_HISTORY 0x18
#define ALS_HISTORY 0x19
#define ADC_OFFSET 0x1A
#define LED_REC 0x1C
#define ALS_IR_ADC_COUNTER 0x1D
#define ALS_IR_ADC_GAIN 0x1E
#define ALS_IR_ADC_MISC 0x1F
#endif
Simple example sketch is here:
/* Si1143 Example */
#define sleep 100
#define led1 57
#define led2 58
#define led3 59
#define led4 60
#include <Wire.h>
#include "SI1143.h";
int bias1,bias2,bias3,PS1,PS2,PS3;
int blinktime,counter,counter1,counter2,Ledposition;
unsigned int Light_Reading;
byte LowB,HighB;
bool selected;
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(50, OUTPUT);
digitalWrite(50, HIGH);
delay(25);
Wire.begin(); // join i2c bus (address optional for master)
delay(25);
write_reg(HW_KEY, 0x17); // Setting up LED Power to full
write_reg(PS_LED21,0xFF);
write_reg(PS_LED3, 0x0F);
param_set(CHLIST,0b00010111);
char parameter = read_reg(PARAM_RD,1);
// Serial.print("CHLIST = ");
// Serial.println(parameter,BIN);
bias();
counter = 0;
counter1 = 0;
counter2 = 0;
selected = 0;
blinktime = 75;
write_reg(COMMAND,0b00000101); // Get a reading
delay(5);
LowB = read_reg(PS1_DATA0,1); // Read the data for the first LED
HighB = read_reg(PS1_DATA1,1);
PS1 = ((HighB * 255) + LowB) - bias1;
LowB = read_reg(PS2_DATA0,1); // Read the data for the second LED
HighB = read_reg(PS2_DATA1,1);
PS2 = (HighB * 255) + LowB - bias2;
LowB = read_reg(PS3_DATA0,1); // Read the data for the third LED
HighB = read_reg(PS3_DATA1,1);
PS3 = (HighB * 255) + LowB - bias3;
Light_Reading = read_light();
if(Light_Reading >= 330) digitalWrite(led4, HIGH);
else digitalWrite(led4, LOW);
if(selected != 1) {
if (counter > 10 || counter1 > 10 || counter2 > 10){
selected = 1;
touch_select();
if (PS1 > 200 || PS2 > 200 || PS3 > 200){
if (PS1 > PS2 && PS1 > PS3){
if (selected == 0){
digitalWrite(led1, HIGH);
digitalWrite(led2, LOW);
digitalWrite(led3, LOW);
counter++;
Ledposition = 1;
counter1 = 0;
counter2 = 0;
}else if(PS2 > PS1 && PS2 > PS3){
if (selected == 0){
digitalWrite(led1, LOW);
digitalWrite(led2, HIGH);
counter1++;
Ledposition = 2;
counter = 0;
counter2 = 0;
}else if(PS3 > PS1 && PS3 > PS2){
if (selected == 0){
digitalWrite(led3, HIGH);
counter2++;
Ledposition = 3;
counter = 0;
counter1 = 0;
}else{
counter = 0;
counter1 = 0;
counter2 = 0;
selected = 0;
//analogWrite(5, map(Light_Reading, 0, 10000, 0, 255));
unsigned int read_light(){ // Read light sensor
write_reg(COMMAND,0b00000110);
delay(sleep);
byte LowB = read_reg(ALS_VIS_DATA0,1);
byte HighB = read_reg(ALS_VIS_DATA1,1);
return (HighB * 255) + LowB;
void param_set(byte address, byte val) // Set Parameter
write_reg(PARAM_WR, val);
write_reg(COMMAND, 0xA0|address);
char read_reg(unsigned char address, int num_data) // Read a Register
unsigned char data;
Wire.beginTransmission(IR_ADDRESS);
Wire.write(address);
Wire.endTransmission();
Wire.requestFrom(IR_ADDRESS, num_data);
while(Wire.available() < num_data);
return Wire.read();
void write_reg(byte address, byte val) { // Write a resigter
Wire.write(val);
void bias(void){ // Bias during start up
for (int i=0; i<20; i++){
delay(50);
byte LowB = read_reg(PS1_DATA0,1);
byte HighB = read_reg(PS1_DATA1,1);
bias1 += ((HighB * 255) + LowB) / 20;
bias2 += ((HighB * 255) + LowB) / 20;
bias3 += ((HighB * 255) + LowB) / 20;
void touch_select(){ // just a blink routine for when something is selected
switch (Ledposition) {
case 1:
for (int i = 0; i < 4; i++){
delay(blinktime);
delay(blinktime);
case 2:
delay(blinktime);
delay(blinktime);
case 3:
delay(blinktime);
delay(blinktime);
Please modify Arduino pin numbers to suit your project, this code lights up led's when you glide hand over them and also flashes led that you selected (stopped your hand over it for period of time)
