how to use additional .c files in a sketch
I am a beginner with the Arduino environment and I need some help figuring out how to use some .c source files in a sketch without creating a library. I tried to find the answer on the forum but I couldn't, I apologize if the solution to my problem is somewhere in the posts and I just missed it.
So, I have a test.h file that contains only:
void doSomething(void);
The test.c file contains:
#include "test.h"
      // there should be some code here
In my sketch, I have:
#include "test.h"
  doSomething();
I am not sure if this was needed or not but I also went to the Sketch menu and use Add File... to include both .h and .c file.
When I compile I get:
o: In function `setup':
C:\DOCUME~1\coprea\LOCALS~1\Temp\build50525.tmp/Temporary_3386_6704.cpp:6: undefined reference to `doSomething()'
C:\DOCUME~1\coprea\LOCALS~1\Temp\build50525.tmp/Temporary_3386_6704.cpp:8: undefined reference to `doSomething()'
If I understand correctly from the Build Process page, this should work so I am sure I am missing something. Thanks for your help in advance!
beginner--
The problem stems from the fact that you are trying to link a C function from a C++ module, without explicitly declaring that fact. There are several solutions, including:
a) rename test.c to test.cpp
b) remove the #include "test.h" from your main sketch and replace it with
extern "C" void doSomething(void);
c) change the header to the clumsy:
#if defined(__cplusplus)
extern "C"
#endif
#endif
etc.
Mikal
Thank you very very much for taking the time to explain this to me, I used the first alternative and it works great.
