Topic: Arduino for Industrial Automation (Read 999 times) previous topic - next topic
gcshwetha
Hello
I am using Arduino for an Industrial automation project. I should be able to do following
- Write good object oriented high performance code.
- Should be able to debug, analyze the code with proper debugging tools and break points
- Would like to go online with the running code and monitor execution (like in PLCs)
- Should be able to write proprietary algorithm.
Could anyone please suggest
- Which programming language is better to use on Arduino? (C, (OOC) C++ or Python)
- Which IDE is recommended?
Any help will be greatly appreciated.
Thanks,
Shwetha.
Robin2
Arduinos are programmed in C/C++
The Atmel MCUs used in the 16MHz Arduinos don't have facilities for in-circuit-debugging
I don't use the Arduino IDE for editing, only for compiling and uploading code. I use the Geany editor
I think you would most easily get an appreciation of the Arduino system by getting an Uno and working through some of the many examples that come with the Arduino IDE and the many online tutorials.
Be careful not to confuse an MCU with 2k of SRAM with the programming space available on a PC.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
68tjs
Quote
The only waranties I know are  those of Smart Project
http://www.arduinosrl.it/catalog/index.php?main_page=warranties&zenid=d18t5fain8rmtvpmbnmcape2p5
Before the fight they are officials for Arduino LLC, now only God knows, and that's not even sure!
Note this excerpt:
Quote
1.5 UNAUTHORIZED USE.- Arduino Srl products are not authorized for use in safety-critical applications where a failure of the Arduino Srl product would reasonably be expected to cause severe personal injury or death. safety-critical applications include, without limitation, life support devices and systems, equipment or systems for the operation of nuclear facilities and weapons systems. Arduino Srl products are neither designed nor intended for use in military or aerospace applications or environments and for automotive applications or environment. customer acknowledges and agrees that any such use of Arduino Srl products which is solely at the customer's risk, and that customer is solely responsible for compliance with all legal and regulatory requirements in connection with such use.
TechnoBubba
Object-Oriented and "High Performance" are IMHO 'mutually-exclusive'. Typically as a result of
"Spaghetti-Classes" ( analogous to "Spaghetti-Code"), but Good Luck, I won't dissuade you any more.
