I got a solution but my server code on arduino does not seems to work. and im using a c# console app to send values to the server.
Arduino server code:
Chat Server
A simple server that distributes any incoming messages to all
connected clients. To use telnet to your device's IP address and type.
You can see the client's input in the serial monitor as well.
Using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 10 August 2010
by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
IPAddress ip(192,168,1,4);
IPAddress gateway(192,168,1,1);
IPAddress subnet(255,255,0,0);
// telnet defaults to port 23
EthernetServer server(23);
boolean gotAMessage = false; // whether or not you got a message from the client yet
// initialize the ethernet device
// start listening for clients
server.begin();
// open the serial port
// wait for a new client:
// when the client sends the first byte, say hello:
if (client) {
if (!gotAMessage) {
Serial.println("We have a new client");
client.println("Hello, client!");
gotAMessage = true;
// read the bytes incoming from the client:
char thisChar = client.read();
// echo the bytes back to the client:
server.write(thisChar);
// echo the bytes to the server as well:
Serial.print(thisChar);
C# code:
/* Client Program */
using System;
using System.IO;
using System.Net;
using System.Text;
using System.Net.Sockets;
public class clnt
public static void Main()
try
TcpClient tcpclnt = new TcpClient();
Console.WriteLine("Connecting.....");
tcpclnt.Connect("192.168.1.4", 80);
// use the ipaddress as in the server program
Console.WriteLine("Connected");
Console.Write("Enter the string to be transmitted : ");
String str = Console.ReadLine();
Stream stm = tcpclnt.GetStream();
ASCIIEncoding asen = new ASCIIEncoding();
byte[] ba = asen.GetBytes(str);
Console.WriteLine("Transmitting.....");
stm.Write(ba, 0, ba.Length);
byte[] bb = new byte[100];
int k = stm.Read(bb, 0, 100);
for (int i = 0; i < k; i++)
Console.Write(Convert.ToChar(bb[i]));
tcpclnt.Close();
catch (Exception e)
Console.WriteLine("Error..... " + e.StackTrace);
The c# console shows connected but the Serial window on Arduino IDE is al blank always even when i send stuff from client.
Just a question.
Arduino server:
// this is port 23
C# client with question:
// is this attempting to connect on port 80?
Yes Yes i got it too as soon i posted , but changed it already in the main programme.
this is in the arduino:(changes)
IPAddress subnet(255,255,255,0);
EthernetServer server(80);
i tried other sketches too; like the DHCP address printer, the case is same here too , nothing is on the Serial Monitor screen and the Baud rate is correct.
However sketches like udpntpclient and webclient work good , can you catch up whats bad here?
You are having trouble with DHCPAddressPrinter? It never shows anything on the serial monitor? It may take up to a minute or more for the request to timeout and print something.
Does this ethernet shield have a microSD slot? Do you have a microSD card in the slot?
It shows stuff on the Serial Monitor, have a look at the Serial prints??!!
DHCP-based IP printer
This sketch uses the DHCP extensions to the Ethernet library
to get an IP address via DHCP and print the address obtained.
using an Arduino Wiznet Ethernet shield.
Circuit:
created 12 April 2011
by Tom Igoe
#include <SPI.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {
0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
// start the serial library:
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
for(;;)
// print your local IP address:
Serial.print("My IP address: ");
for (byte thisByte = 0; thisByte < 4; thisByte++) {
// print the value of each byte of the IP address:
Serial.print(Ethernet.localIP()[thisByte], DEC);
Serial.print(".");
Serial.println();
Yes i have a 512MB SD card in it.!!!!!!
One more thing im getting into using the port 80 in both place here :
and
bcz c# app wont get connected with 23 as port it sticks till connecting.....
That is the challenge.
// disable the SD card SPI
pinMode(4,OUTPUT);
digitalWrite(4,HIGH);
// and the rest
That will prevent DhcpAddressPrinter from working also. Remove the microSD card as a test. It should work then.
I took the SD card from that moment on and reprogrammed the Processor with the following code:
Chat Server
Circuit:
created 18 Dec 2009
by David A. Mellis
by Tom Igoe
#include <SPI.h>
server.begin();
Serial.print("done");
if (client) {
if (!gotAMessage) {
gotAMessage = true;
and changed this in C#:
i think its all is correct but still the serial monitor shows nothing and nothing happens when i send from c# programme also the DHCPAddress printer i left for 4-5 minutes it still shows the Serial monitor Clean!
My computers IP is 192.168.1.2
edit: My bad. The Arduino ip is 192.168.1.4. The computer is 192.168.1.2. Is that right?
Can you ping 192.168.1.4 from the computer?
No sir it says Request timed out
Try DhcpAddressPrinter again with the SD card removed. Can you ping the Arduino at the new ip?
Yes but i have to disconnect the Ethernet and plug into the Itead Iboard (that equals shield as W5100 is used on it too) and utilise the GPRS on my handset on the computer for internet till im testing.
and as such the ethernet adapter Local area network 3 says:
ipv4 address is: 192.168.42.226 , so is it this i need to use?
Now i have removed the SD card and im not inserting it anymore till i make this work without it.Thanks!
Why does that sound like a conversation between Kirk and Scotty? I don't have a clue.
Sorry for that because i even didn't have the attention to this particular aspect i didn't thought about it.
so what to here? do i need to mould the Arduino programme IP as in 192.168.42.5/6/7 etc i mean on the same domain?
and moreover in the Arduino CharServer it says
so changing it to 80 is ok or not? i did it bcz at 23 port number the c# programme just stands at connecting..... and with 80 as port its able to access the server and prompt for "Enter the string to be transmitted : "
