I want to measure distance with the URM37 V3.2 to a UNO R3
I followed the instructions on:
http://milesburton.com/URM37_Ultrasonic_Distance_Measurement_Library
What i get is:
avrdude: stk500_getsync(): not in sync: resp=0x00
Also i get some random feedback:
DDistance=12834""Distance=12834""Distance=12834""Distance=12834""Distance=13090""""Distance=-256""Distance=-11""
/* Ultrasound Sensor
* URM V3.2 ultrasonic sensor TTL connection with Arduino
* Reads values (0-300) from an ultrasound sensor (3m sensor)
* and writes the values to the serialport.
* Pin12 (Arduino)-> Pin 1 VCC (URM V3.2)
* GND (Arduino) -> Pin 2 GND (URM V3.2)
* Pin11 (Arduino) -> Pin 7 (URM V3.2)
* Pin 0 (Arduino) -> Pin 9 (URM V3.2)
* Pin 1 (Arduino) -> Pin 8 (URM V3.2)
* www.yerobot.com
* Last modified 20/04/2009
int UREnable = 11; // Ultrasound enable pin
int URPower = 12; // Ultrasound power pin
int val = 0;
int USValue = 0;
int timecount = 0; // Echo counter
int ledPin = 13; // LED connected to digital pin 13
boolean flag=true;
uint8_t DMcmd[4] = { 0x22, 0x00, 0x00, 0x22}; //distance measure command
Serial.begin(9600); // Sets the baud rate to 9600
pinMode(ledPin, OUTPUT); // Sets the digital pin as output
pinMode(UREnable, OUTPUT);
digitalWrite(UREnable, HIGH); // Set to High
pinMode(URPower, OUTPUT);
digitalWrite(URPower, HIGH); // Set to High
delay(200); //Give sensor some time to start up --Added By crystal from Singapo, Thanks Crystal.
flag=true;
//Sending distance measure command : 0x22, 0x00, 0x00, 0x22 ;
for(int i=0;i<4;i++)
Serial.write(DMcmd[i]);
delay(75); //delay for 75 ms
while(flag)
if(Serial.available()>0)
int header=Serial.read(); //0x22
int highbyte=Serial.read();
int lowbyte=Serial.read();
int sum=Serial.read();//sum
if(highbyte==255)
USValue=65525; //if highbyte =255 , the reading is invalid.
USValue = highbyte*255+lowbyte;
Serial.print("Distance=");
Serial.print(USValue);
Serial.print("/n");
flag=false;
delay(50);
If any additional information is needed I'll gladly add it to the post. I have tried several different code-templates, but none seem to work. On the 'old' arduino everything works as aspected. What changes are made? There is also a significant difference between Arduino22 and Arduino 1.0. It looks like the new arduino SDK is not compatible with the Ultrason. Is this true?
