Topic: INA118 instrumentation amplifier (Read 2187 times) previous topic - next topic
lcruz007
Dec 02, 2010, 05:21 am Last Edit: Dec 02, 2010, 06:04 am by lcruz007 Reason: 1
Hello,
I'm currently trying to make the INA118 (instrumentation amplifier) work, but the amplifier is not working whatsoever.
Please check my schematics:
http://img403.imageshack.us/img403/8508/circuit.png
The oscilloscope measure states that the signal is just 200mV, which doesn't coincides with my calculations. That's a gain of 50. There's a small voltage difference with respect to the voltage reference, which could perfectly be amplified.
What am I doing wrong?
RuggedCircuits
I don't follow your voltage divider values. R2 and R1 together should give:
5 * R2/(R2+R1) = 0.0234V, not 0.22V as you write
Similarly, R5 and R6 combine as:
5 * R6/(R5+R6) = 0.0495V and not 0.4545V as you write.
The Rugged Motor Driver: two H-bridges, more power than an L298, fully protected
lcruz007
#2
Dec 02, 2010, 06:15 am Last Edit: Dec 02, 2010, 06:22 am by lcruz007 Reason: 1
The 0.022 is the approximate voltage I get by the multimeter,   0.023390067 is not rounder. And as I stated in the schematics, r3 and r4  should give a voltage ~ 0.045V... and the other input should be around 0.05V according to my multimeter.
Is that right no?
Remember that I won't get an exact number as the resistors have a tolerance of 5% in the first place. :)
RuggedCircuits
Yes, but your schematic says 0.22V, not 0.022V.
No, they give a voltage ~0.455V.
You are also not really working within the allowable common-mode range of this device. If you look at the "Linear Input Voltage Range" parameter on the datasheet you see that it expects the minimum input voltage (at pins 2 and 3) to be about 1V above ground.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, light sensor, potentiometers, pushbuttons
