The reason you use an interrupt is so the task, which in this case is outputting the next sample, can be done at precisely the right moment. Because there is such a small interval between fetches then polling to see if the time is right is not only inefficient but does not give you fine enough control. The microseconds timer only gets updated every four microsecond for a start and then the other task or tasks in the Sate machine have to be completed in under the time between samples, which puts a lot of limitations on them. For example it means you can't do an analogRead while playing a sample without disturbing the timing.
By using an interrupt any other task gets suspended and your sample is changed on time. I would not say that non of the tutorials use this technique but as I said at the start of the thread there is a lot of crap out there. And an Instructables url is one way you can spot crap.
Correct me if I'm wrong. Do you mean that many mandatory functions inevitably consume a significant amount of time and it's impossible to achieve a 100% perfect timing? Well... at least is comprehensible that even delayMicroseconds is accurate enough, but not perfect (I guess due to clock rate).
Yes. And that is with a task that contains only the one instruction, you will have to insure that all your tasks complete in significantly shorter time than the sample rate. Even then there will be a jitter of a time period equal to the length of your longest task. Using a delay is just a "baby" stop gap used as a demonstration or where you don't want to do anything else while a sound is playing.
Any delay is blocking so your processor can not do anything else while it is waiting. A jitter of 4uS might not be noticeable at the low quality you have at the moment but it will soon show up as noise on your output. Remember 4uS equates to 64 clock cycles, about the same time as a digital write function call.
Grumpy_Mike:
Now I understand your point even better. You mean that I have a kind of "time budget" to do other things without compromising the sample rate, right?
If so, then I just have 53 microseconds to do other stuff (the time I'm "wasting" in a delay, in order to provide to the runtime a "time gap").
Is that enough time to do a AnalogRead and map functions? Because I wanna give to my current player a new feature: adjust the pitch (and speed along the way) with a potentiometer. Yeah, I had that crazy idea in my head since yesterday. It sounds like a something called "circuit bending"...
What kind of noise? A "waveform glitch" or something worse enough to blow off an amplifier?
Right.
What kind of noise?
Time quantisation noise sometimes called sample noise. It is noise, that is signals that do not belong in there.
There are ways round the default analogRead, like to set the A/D in free running mode. But do it right and use interrupts, and let the other stuff that can wait, wait.
Grumpy_Mike:
How exactly can I do that? Do you mean that the "free running mode" will take less CPU cycles than AnalogRead function? But how can I retrieve the measures?
And what about the map function? How long it takes?
There is noting that returns an 8 bit value, you just have to use the 8 most significant bits of the returned value. Shift right by two places is the way to do it.
Grumpy_Mike:
So do you mean that the ADC always return a 10 bit value?
If so, please explain me a bit more that line of code that sets the analog input pins in "fast mode", how to retrieve the data with this new configuration and how to discard the two bits.
Yes.
The A/D works with a clock that controls the timing, that line alters the pre scaler division ratio so that the clock runs faster and so the A/D runs faster.
For full information see section 23 of the ATmega328 data sheet.
Exactly the same as before, with an analogRead function call. I told you about the shift operation to remove the lower two bits:-
Is there a way to measure the time that a funcion takes to execute? (in clock "ticks"). Because, I don't know exactly how long the AnalogRead function takes in the "fast mode".
And I found a problem by discarding the two bits. For example: if the 10-bit value is 256, 512 or 768; discarding the two most significant bits will result in a 8-bit value of 0 (zero), in all those three cases.
I want to clear all my doubts before put anything in practice...
Why on Earth would you discard the most significant bits?
Grumpy_Mike:
Use the micros timer for timing function calls.
Sorry for my ignorance, but how can I do that?
I mean, I want to execute a function, and then print the amount of ticks that the function took, to the serial monitor of course.
That code discards the two least significant bits not the most. Are you sure you understand what a shift operation is doing?
Whoops, my bad. You mean the LEAST significant bits, not the MOST ones. Very well, it works for me then...
