I am really looking forward to using this IDE. It is just what I was looking for. I having some issues with it right now, though. To use some library, I believe you said all you have to do is copy the files into your project folder and then include them.
So...I copied the normal Servo.h and Servo.cpp files into my project, and then added them to my project. However, when I build, I got four identical errors on four similar areas of code in Servo.cpp
error: cannot convert 'uint8_t* {aka unsigned char*}' to 'volatile uint16_t* {aka volatile short unsigned int*}' for argument '2' to 'void handle_interrupts(timer16_Sequence_t, volatile uint16_t*, volatile uint16_t*)'|
and the four pieces of code are identical, except the timer numbers are changed. the error is on the handle_interrupts line. If anyone is looking for this part of the Servo.cpp code, the first error is on line 105
#if defined(_useTimer1)
SIGNAL (TIMER1_COMPA_vect)
handle_interrupts(_timer1, &TCNT1, &OCR1A);
#endif
I would love to get this working because this seems a much better IDE and i have been looking for an Arduino simulator.
I just installed CodeBlocks (Revision 20130402), and I have tried to use it with my Arduino Mega 2560. It builds without any issues, but it gives an "error generating HEX file" message.
I have just created the default "LED on for one second, then off for one second" routine that is included by default when you create a new project. I saw some people asking the same questions before, but I can not see any specific resolution.
Can anyone please give some advice - or is this a known bug in CodeBlocks when using it with say Arduino Mega?
I downloaded CodeBlocks and tried to open a simple test project and compiling it.
But nothing compiles, not even a single example:
A lot of compiler errors which I could eliminate by setting -fpermissive. But why? Why no problems on Arduino IDE??
A lot of cannot open/find/missing header file
I tried to add files to the project, but that only results in more compiler errors in the Arduino files (like malloc.c). Some of the header files still can't be found, although I added the complete Arduino libraries folder (recursively) to the project...
So I'm doing something wrong, but can't find any manual to setup codeblocks for the Arduino environment and get a WORKING environment that does compile existing sketches and libraries, just as the Arduino IDE...
Update @8 July:
I downloaded Stanleys ArduinoOBD / obdlogger, and was able to compile that project using Code::Blocks, so at least I know that the intallation of Code::Blocks is ok!
Now if I can find why this project compiles fine, and mine not, I guess I found the problem
I really like Code::Blocks features, so must find a way to compile my own sketches and libraries!
I have exact same problem and didn't find answer.... can anybody help? If I start ArduinoBuilder manually and select file, it works. I guess there is a problem with settings in CodeBlocks? I tried some, but no success.
I've downloaded version 20130704, but when installed, it says ver 12.11 build nov 25 2012 !?
Thanks,
Damo
janleroux:
Stanley, board is selected properly in Codeblocks and in Arduino builder (mega2560).
It works ok, if I compile, build in Codeblocks and then manually start Arudino builder, choose hex file manually and upload.
I guess something is wrong in codeblocks porting to arduino builder, but all is original settings, I tried some alterations, but no success, then I owerwrite it with original.
Ok, and how do you recompile-rebuild so that the hack starts to work?
TIA,
Fernando.
stanleyhuang:
Actully my long-term goal is to implement a simulator which acts like a http server and use HTML to render the simulation.
About hacking into arduino core files, taking digitalWrite as an example, I just added one line at the end like this:
void digitalWrite(uint8_t pin, uint8_t val)
uint8_t timer = digitalPinToTimer(pin);
uint8_t bit = digitalPinToBitMask(pin);
uint8_t port = digitalPinToPort(pin);
volatile uint8_t *out;
if (port == NOT_A_PIN) return;
// If the pin that support PWM output, we need to turn it off
// before doing a digital write.
if (timer != NOT_ON_TIMER) turnOffPWM(timer);
out = portOutputRegister(port);
uint8_t oldSREG = SREG;
cli();
if (val == LOW) {
*out &= ~bit;
*out |= bit;
SREG = oldSREG;
#ifdef ARDUSIM
fprintf(stderr, "[MCU] Pin %d state changed to %s\n", pin, val ? "HIGH" : "LOW"); #endif
> tianshuo:
> I see them alright, but I'm not sure where should I start from. I guess maybe the simulator could listen to a port for signals?
> Could someone give an example using wiring_analog.c?
Hmmm... if this is a reply to my question, maybe I didn't ask it in the right way. I was asking about your suggestion for hacking the simulator by using code inside
#ifdef ARDUSIM
... #endif
which actually I did. However, when I open the ardusim.cbp with the Code::Blocks you provide I obtain a lot of errors (I could send the compiler-linker report, just ask). I've finally got to simulate a digital pin input from file, but doing some extra-hacking stuff, which I prefer not to send, since I think I'm doing something wrong with ardusim.cbp and I would like to fix it.
TIA,
Fernando.
stanleyhuang:
The simulation code is in the core files (a different version). There is no need to rebuild. It is built and linked with sketch.
Newbie here...testing driving the Arduino CB IDE...how does one send a command/message via the Arduino Builder serial interface??? I can upload the sketch successfully, and can open a serial port at the desired baudrate, but how do I send a command to the Arduino??? Serial.print()?
I am working on a exercise where you instruct RGB LED's to turn on to a set level....using the serial interface in Arduino IDE I can successfully change the LEDs but at a sticking point via the CB Arduino IDE...thanks.
Great work on the Code::Blocks for Arduino. I had some difficulty getting the software to work on Windows 7 at first, however I was able to find a work around. Here is was my original problem. When I try to do a "build and run" from Code::Blocks for the blink example, the Arduino Builder pops up. Afterwards, I click COM3 but it gives me the following message: "Error generating HEX file."
My alternative solution was this. I did a "build" only using the blink example. Afterwards, I open the Arduino Builder, click Load Sketch / HEX and then click COM3. This solution worked. Although this solution is a bit slower, it still works. Do you have any suggestions/ideas why the build and run is not working from the Code::Blocks IDE?
On another note, I am attempting to get the CB for Arduino to work on Ubuntu 12. No luck so far but I will let you know if I have anymore luck.
Ok, pretend I'm new at this.
I downloaded the file CodeBlocks-Arduino-20130827.7z now what do I do with it? It's not an a Plugin, but it's not going to install it's self either. I see people taking about having just installed it. I though it would be a plugin for CodeBlocks... Help, I want in on the fun
The ".7z" extension on the file name means it has been compressed with 7-Zip. You will need to locate, download, and install 7-Zip in order to decompress the file. What to do next depends on what you get after the decompression. If it is only a couple files, one having a ".exe" extension, then it has an installer. Just run the file with that extension and a wizard will guide you through the process. If instead you end up with hundreds of files in a dozen or more directories folders, then this is the actual program, and you just need to move it to a convenient location where you have read/write access. I don't remember which it is as it was a while ago that I tried it. I should also mention that this is a complete Code::Blocks package, not just a plug-in. Hope this helps.
