I am attempting to use the EasyVR shield(Manual) to trigger the MP3 Trigger (Manual).
I have a working code for the EasyVR so that it recognizes the commands. I have implemented the MP3 Trigger code into the EasyVR sketch but it spits out garbled letters on the IDE monitor. I know that it has to the Serial communication that is screwing things up, but I do not know how to solve it.
This first sketch is for the MP3 Trigger, and it works.
#include <SoftwareSerial.h>
#include <MP3Trigger.h>
SoftwareSerial trigSerial = SoftwareSerial(2, 3);
MP3Trigger trigger;
void setup ()
trigger.setup(&trigSerial); //This also starts the serial for this device
Serial.begin( MP3Trigger::serialRate() );
trigger.update();
if (Serial.available())
char LETTER_FROM_COMPUTER = Serial.read();
if (LETTER_FROM_COMPUTER == 1)
trigger.play(2);
This sketch is for the EasyVR, which also works at recognizing my commands.
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#include "SoftwareSerial.h"
SoftwareSerial port(12,13);
#else // Arduino 0022 - use modified NewSoftSerial
#include "WProgram.h"
#include "NewSoftSerial.h"
NewSoftSerial port(12,13);
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
//Groups and Commands
enum Groups
GROUP_0 = 0,
GROUP_1 = 1,
enum Group0
G0_MICA = 0,
enum Group1
G1_HELLO = 0,
G1_HOW_ARE_YOU = 1,
EasyVRBridge bridge;
int8_t group, idx;
// bridge mode?
if (bridge.check())
cli();
bridge.loop(0, 1, 12, 13);
// run normally
port.begin(9600);
if (!easyvr.detect())
Serial.println("EasyVR not detected!");
for (;;);
easyvr.setPinOutput(EasyVR::IO1, LOW);
Serial.println("EasyVR detected!");
easyvr.setTimeout(5);
easyvr.setLanguage(0);
group = EasyVR::TRIGGER; //<-- start group (customize)
void action();
easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
Serial.print("Say a command in Group ");
Serial.println(group);
easyvr.recognizeCommand(group);
do
// can do some processing while waiting for a spoken command
while (!easyvr.hasFinished());
easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
idx = easyvr.getWord();
if (idx >= 0)
// built-in trigger (ROBOT)
// group = GROUP_X; <-- jump to another group X
return;
idx = easyvr.getCommand();
if (idx >= 0)
// print debug message
uint8_t train = 0;
char name[32];
Serial.print("Command: ");
Serial.print(idx);
if (easyvr.dumpCommand(group, idx, name, train))
Serial.print(" = ");
Serial.println(name);
Serial.println();
easyvr.playSound(0, EasyVR::VOL_FULL);
// perform some action
action();
else // errors or timeout
if (easyvr.isTimeout())
Serial.println("Timed out, try again...");
int16_t err = easyvr.getError();
if (err >= 0)
Serial.print("Error ");
Serial.println(err, HEX);
void action()
switch (group)
case GROUP_0:
switch (idx)
case G0_MICA:
// write your action code here
// group = GROUP_X; <-- or jump to another group X for composite commands
break;
break;
case GROUP_1:
switch (idx)
case G1_HELLO:
break;
case G1_HOW_ARE_YOU:
break;
break;
Now, as I have said earlier, I have tried to incorporate the MP3 Trigger sketch into the EasyVR sketch so that when I say a command, it triggers a track from the MP3 Trigger. This sketch compiles and uploads but it spits out garbled characters on the Monitor and, of course, doesn't work. (i.e. it doesn't trigger a sound). Below is the combined sketches, which, I am sure, is totally wrong. I believe it has to do with the Serial communication, but don't know enough to make this work.
#endif
#include "EasyVR.h"
SoftwareSerial trigSerial = SoftwareSerial(12, 13);
MP3Trigger trigger;
enum Groups
GROUP_0 = 0,
GROUP_1 = 1,
enum Group0
G0_MICA = 0,
enum Group1
G1_HELLO = 0,
G1_HOW_ARE_YOU = 1,
int8_t group, idx;
// bridge mode?
if (bridge.check())
cli();
// run normally
port.begin(9600);
for (;;);
void action();
trigger.update();
do
if (idx >= 0)
return;
if (idx >= 0)
uint8_t train = 0;
char name[32];
Serial.print(idx);
Serial.println();
action();
if (err >= 0)
void action()
switch (group)
case GROUP_0:
switch (idx)
case G0_MICA:
group = GROUP_1;// <-- or jump to another group X for composite commands
break;
break;
case GROUP_1:
switch (idx)
case G1_HELLO:
trigger.play(2);// write your action code here
break;
break;
break;
EasyVRBridge.cpp (3.26 KB)
EasyVRBridge.h (1.77 KB)
MP3Trigger.cpp (2.66 KB)
MP3Trigger.h (1.32 KB)
