It looks like the I2C bus lines are being pulled from the A4 and A5 pins on the arduino. My question is, can I use this with the leonardo or the UNO R3?
are the I2C pins exclusively on the SDA and SCL pins for the R3 layout, or can I still pull the I2C pins from the A4 and A5?
funkyguy4000:
So its jsut the 32U4 that is the issue. thank you!
No, it's what model main processor chip is being used that determines where the I2C pins are mapped to. The mega2560 and 1280 chips use different I2C pins then the 328p chip (and also the 32U4). The Arduino team has made a change to the shield pin layout on their newest boards (starting with the Leonardo board) to help solve this problem for future main boards and future shield boards by placing two new shield pins adjacent to the Aref pin so that the two I2C signals will be at a fixed location no matter what model main processor chip the board uses. That will not help present controller boards (except for the Leonardo) or present shield modules, but does give a 'fix' going forward.
retrolefty:
This change didn't start with the Leonardo. The "R3" versions of the Mega and Uno started with I2C pins next to AREF. These pins are physically connected to the same pins as A4 and A5 on the Uno.
