const int floodSensor1 = 2; // the number of the Flood Sensor pin
const int floodSensor2 = 3; // the number of the Flood Sensor pin
const int floodSensor3 = 4; // the number of the Flood Sensor pin
const int floodSensor4 = 5; // the number of the Flood Sensor pin
const int floodSensor5 = 6; // the number of the Flood Sensor pin
const int floodSensor6 = 7; // the number of the Flood Sensor pin
const int floodSensor7 = 8; // the number of the Flood Sensor pin
An array would make a lot more sense, and use a lot less code.
floodSensorState = HIGH;
The flood condition might be true. But, there is no (single) flood sensor, so it's state can't possibly be HIGH. A more meaningful name is in order.
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
Send a standard response, regardless of what the client asked for. Not a good plan.
