I've done some research before posting this but can't get an answer that makes sense.
I'm using Processing 2.2.1 to read serial data from a Uno and write it to a file. All good so far, it's working as expected. The data supplied from the usb port "appears" numeric when read off the A/D converter 0-1023. But it's not really numeric, it's a string.
I can understand why because of "sensorValue = myPort.readString();" so I guess reading from the serial port is considered as a string in any programming language?.
Regardless, I need to convert it to numbers so I can do some basic math calculations.
Yes, I did realise readString() was going to return a string but there didn't appear to be any other option. According to the reference, read() returns a number between 0-255.
In fact, I will ultimately need to read 0-32767 (15 bit). I was under the impression that the type int was 0-255, therefore I thought I needed long. Although I have now read from the reference "Datatype for integers, numbers without a decimal point. Integers can be as large as 2,147,483,647 and as low as -2,147,483,648." ???
Which has now confused me even more.
Thanks for the link. So the code would look something like this?:
string sensorValue;
int sensorValueNumber = Integer.parseInt(sensorValue);
println(sensorValueNumber);
