Chaps,
I have already sent the OP a table of notes - in phaseincrement form which is ultimatley what an interrupt driven synth like the Auduino needs.
This is then indexed by another table for each scale. Both tables are stored in progmem and accessed through two helper functions - like so -
#ifndef _NOTETABLES_
#define _NOTETABLES_
#include "avr/pgmspace.h"
#define MIDI_NOTES 128
// used to convert midi note numbers into the increments required to generate the note in the ISR
PROGMEM unsigned int midiNoteToWavePhaseIncrement[MIDI_NOTES] =
66 // 0,8.18,66.98,66 C
,70 // 1,8.66,70.96,70
,75 // 2,9.18,75.18,75
,79 // 3,9.72,79.65,79
,84 // 4,10.30,84.38,84
,89 // 5,10.91,89.40,89
,94 // 6,11.56,94.72,94
,100 // 7,12.25,100.35,100
,106 // 8,12.98,106.32,106
,112 // 9,13.75,112.64,112
,119 // 10,14.57,119.34,119
,126 // 11,15.43,126.43,126
,133 // 12,16.35,133.95,133 C
,141 // 13,17.32,141.92,141
,150 // 14,18.35,150.35,150
,159 // 15,19.45,159.29,159
,168 // 16,20.60,168.77,168
,178 // 17,21.83,178.80,178
,189 // 18,23.12,189.43,189
,200 // 19,24.50,200.70,200
,212 // 20,25.96,212.63,212
,225 // 21,27.50,225.28,225
,238 // 22,29.14,238.67,238
,252 // 23,30.87,252.86,252
,267 // 24,32.70,267.90,267 C
,283 // 25,34.65,283.83,283
,300 // 26,36.71,300.71,300
,318 // 27,38.89,318.59,318
,337 // 28,41.20,337.53,337
,357 // 29,43.65,357.60,357
,378 // 30,46.25,378.87,378
,401 // 31,49.00,401.40,401
,425 // 32,51.91,425.27,425
,450 // 33,55.00,450.55,450
,477 // 34,58.27,477.34,477
,505 // 35,61.74,505.73,505
,535 // 36,65.41,535.80,535 C
,567 // 37,69.30,567.66,567
,601 // 38,73.42,601.42,601
,637 // 39,77.78,637.18,637
,675 // 40,82.41,675.07,675
,715 // 41,87.31,715.21,715
,757 // 42,92.50,757.74,757
,802 // 43,98.00,802.79,802
,850 // 44,103.83,850.53,850
,901 // 45,110.00,901.11,901
,954 // 46,116.54,954.69,954
,1011 // 47,123.47,1011.46,1011 C
,1071 // 48,130.81,1071.60,1071
,1135 // 49,138.59,1135.32,1135
,1202 // 50,146.83,1202.83,1202
,1274 // 51,155.56,1274.36,1274
,1350 // 52,164.81,1350.13,1350
,1430 // 53,174.61,1430.42,1430
,1515 // 54,185.00,1515.47,1515
,1605 // 55,196.00,1605.59,1605
,1701 // 56,207.65,1701.06,1701
,1802 // 57,220.00,1802.21,1802
,1909 // 58,233.08,1909.38,1909
,2022 // 59,246.94,2022.92,2022
,2143 // 60,261.63,2143.20,2143 C
,2270 // 61,277.18,2270.64,2270
,2405 // 62,293.66,2405.66,2405
,2548 // 63,311.13,2548.71,2548
,2700 // 64,329.63,2700.27,2700
,2860 // 65,349.23,2860.83,2860
,3030 // 66,369.99,3030.95,3030
,3211 // 67,392.00,3211.18,3211
,3402 // 68,415.30,3402.12,3402
,3604 // 69,440.00,3604.42,3604
,3818 // 70,466.16,3818.75,3818
,4045 // 71,493.88,4045.83,4045
,4286 // 72,523.25,4286.41,4286 C
,4541 // 73,554.37,4541.29,4541
,4811 // 74,587.33,4811.33,4811
,5097 // 75,622.25,5097.42,5097
,5400 // 76,659.26,5400.53,5400
,5721 // 77,698.46,5721.67,5721
,6061 // 78,739.99,6061.89,6061
,6422 // 79,783.99,6422.36,6422
,6804 // 80,830.61,6804.25,6804
,7208 // 81,880.00,7208.85,7208
,7637 // 82,932.33,7637.51,7637
,8091 // 83,987.77,8091.66,8091
,8572 // 84,1046.50,8572.82,8572 C
,9082 // 85,1108.73,9082.58,9082
,9622 // 86,1174.66,9622.66,9622
,10194 // 87,1244.51,10194.85,10194
,10801 // 88,1318.51,10801.07,10801
,11443 // 89,1396.91,11443.33,11443
,12123 // 90,1479.98,12123.79,12123
,12844 // 91,1567.98,12844.71,12844
,13608 // 92,1661.22,13608.50,13608
,14417 // 93,1760.00,14417.70,14417
,15275 // 94,1864.65,15275.02,15275
,16183 // 95,1975.53,16183.31,16183
,17145 // 96,2093.00,17145.63,17145 C
,18165 // 97,2217.46,18165.16,18165
,19245 // 98,2349.32,19245.31,19245
,20389 // 99,2489.01,20389.70,20389
,21602 // 100,2637.02,21602.14,21602
,22886 // 101,2793.83,22886.67,22886
,24247 // 102,2959.95,24247.58,24247
,25689 // 103,3135.96,25689.42,25689
,27216 // 104,3322.44,27216.99,27216
,28835 // 105,3520.00,28835.39,28835
,30550 // 106,3729.31,30550.04,30550
,32366 // 107,3951.06,32366.63,32366
,34291 // 108,4186.01,34291.26,34291 C
,36330 // 109,4434.92,36330.32,36330
,38490 // 110,4698.64,38490.65,38490
,40779 // 111,4978.03,40779.41,40779
,43204 // 112,5274.04,43204.25,43204
,45773 // 113,5587.65,45773.32,45773
,48495 // 114,5919.91,48495.14,48495
,51378 // 115,6271.92,51378.79,51378
,54433 // 116,6644.87,54433.96,54433
,57670 // 117,7040.00,57670.76,57670
,61100 // 118,7458.62,61100.07,61100
,64733 // 119,7902.13,64733.26,64733
,3046 // 120,8372.02,68582.53,3046 C
,7124 // 121,8869.84,72660.64,7124
,11445 // 122,9397.27,76981.30,11445
,16022 // 123,9956.06,81558.77,16022
,20872 // 124,10548.07,86408.50,20872
,26010 // 125,11175.30,91546.65,26010
,31454 // 126,11839.81,96990.28,31454
,31454 // 127,11839.81,96990.28,31454 // this is wrong, need to calculate correct value, even though at 8Khz its wrapping around on every tick
// Pentatonic scale
// C D E G A C
// to map to midi note
#define PENTATONIC_NOTES 54
// provides an index of pentatonic notes in the midi note table
PROGMEM unsigned char sPentatonicNotes[PENTATONIC_NOTES] =
0, 2, 4, 7, 9,
12, 14, 16, 19, 21,
24, 26, 28, 31, 33,
36, 38, 40, 43, 45,
48, 50, 52, 55, 57,
60, 62, 64, 67, 69,
72, 74, 76, 79, 81,
84, 86, 88, 91, 93,
96, 98,100,103,105,
108,110,112,115,117,
120,122,124,127
unsigned int getMidiNotePhaseIncrement(unsigned char sNote)
return pgm_read_word(midiNoteToWavePhaseIncrement + (sNote));
// Duane B 08/11/2012
// change the function to take an unmapped analog input
// and do the mapping to the note range of the scale inside the function
// instead of in loop
unsigned int getPentatonicPhaseIncrement(unsigned int nAnalogInput)
// map the analog input value from 0,1024 to 0 to the number of notes in our scale
uint8_t sPentatonicNote = map(nAnalogInput,0,1024,0,PENTATONIC_NOTES);
uint8_t sMidiIndex = pgm_read_byte(sPentatonicNotes + sPentatonicNote);
return pgm_read_word(midiNoteToWavePhaseIncrement + sMidiIndex);
#endif
If the OP or anyone esle wants to add additional scales, post them back here and we can have a useful resource.
code in action -
Duane B
rcarduino.blogspot.com
