I think that consistent indentation helps make code more readable, and can sometimes highlight logical mistakes.
irrecv.resume();
That just tells it to go get ready to receive another input. It does not determine whether any input was received, nor does it decode the results.
I think you would be far ahead if you separated the "get a value" code from the "use a value" code.
Create functions for each of the "use a value" cases. Call them when the appropriate value is present.
If you don't want to redo the function if a new value has not arrived (as in it is unlikely that "go faster" should be repeated), then, in that case, set the last value received to a do nothing value, like 0.
AWOL:
Im actually pretty happy you guys told me about Ctrl + T because I didn't know about it. I code in Autoit at work, and we have a separate Tidy and Cleanup program that removes all comments, fixes indentation and removes empty lines which helps in the space of the code. I'm thinking of adapting it for Arduino, because it would be easy to do. I would call it a pre compiler
As for the actual code, my overall goal is to make an LED sequencer which will eventually include various other blink patterns that listen to sound. If I am having this much trouble with this simple fade issue, I am getting scared to go into sound. I finished an amazing huge project at work with over 1700 lines of code, so I got gitty thinking I could jump into C++ and do the same thing.
I was hoping some good examples already existed out there, but after doing some searching, I had no luck.
PaulS:
irrecv.resume();
I will give that a try.. I guess I can separate the two, and try to call the read function separately through the code. I just have to figure out how to make the code say ' While running this fade, using the least amount of time, check the IR Rec pin and see if any of the pre-defined values have been seen, and run the loop if they have to execute the proper function'.
I am off to work so I may not reply for a bit..
I have been working on this and no luck..
All I need is for this script to be able to pick up an IR signal and change whats its doing while its in the middle of fading..
I'm thinking its not possible. :~
I posted this another time but no one could help due to the formatting of the code..
I have a decent script set up to blink LED's using an old blu-ray player remote. As it stands, the remote has numbered buttons, volume buttons etc.. It also has a red, green, blue and yellow button. I have it so if I push the R, G or B button, the LED of that color lights up. If I push Yellow, it shuts everything off. I am trying to incorporate fading into this, and while it will being and run the fade, it will no longer pay attention to the IR remote during the fade. I tried removing all delays, and even adding in some calls to read the IR, but no matter what I do, the Fade codes stay going until I reset the Arduino.
While any of the fades are going, I can't get Arduino to check the IR for changes.
I have 2 versions of the code, I would love for either one to work. One uses IF statements, the other uses WHILE statements:
// include
#include <IRremote.h>
int RECV_PIN = 11;
int periode = 2000;
int displace = 500;
int testtime = 1000;
long time=0;
/* FUTURE USE
int RED1 = 2;
int GREEN1 = 3;
int BLUE1 = 4;
int RED2 = 5;
int GREEN2 = 6;
int BLUE2 = 7;
int RED3 = 8;
int GREEN3 = 9;
int BLUE3 = 10;
int RED4 = 11;
int GREEN4 = 12;
int BLUE4 = 13;
int redPin = 7; // Red LED, connected to digital pin 9
int grnPin = 6; // Green LED, connected to digital pin 10
int bluPin = 8; // Blue LED, connected to digital pin 11
int value, value2, value3 ;
int RED = 7;
int GREEN = 6;
int BLUE = 8;
// Color arrays
int black[3] = {
0, 0, 0 };
int white[3] = {
100, 100, 100 };
int red[3] = {
100, 0, 0 };
int green[3] = {
0, 100, 0 };
int blue[3] = {
0, 0, 100 };
int yellow[3] = {
100, 100, 0 };
int pink[3] = {
0, 100, 100 };
int magenta[3] = {
100, 0, 100 };
// etc.
// Set initial color
int redVal = black[0];
int grnVal = black[1];
int bluVal = black[2];
//int wait = 2; // no longer used
int prevR = redVal;
int prevG = grnVal;
int prevB = bluVal;
IRrecv irrecv(RECV_PIN);
decode_results results;
long previousMillis = 0;
long interval = 1000;
long chill = 2;
int ledState = LOW; // only for BLUE LED for now, will add more later, just want to blink blue for now
int blinkone = 0;
int blinktwo= 0;
int blinkthree = 0;
int blinkfour = 0;
int blinkfive = 0;
int blinksix = 0;
int blinkseven = 0;
int blinkeight = 0;
int blinknine = 0;
int val;
pinMode(8, OUTPUT);
pinMode(7, OUTPUT);
pinMode(6, OUTPUT);
irrecv.enableIRIn(); // kick on the IR receiver
unsigned long currentMillis = millis(); // Start the arduino counting so it can keep time
if (irrecv.decode(&results)) {
while (results.value == 0x66B47) { // BLUE button on the remote
digitalWrite(BLUE, HIGH);
while (results.value == 0xE6B47) { // RED button on the remote
digitalWrite(RED, HIGH);
while (results.value == 0x490) { // Vol Up button on the remote
interval = interval - 50;
if (interval < 75) {
interval =100;
while (results.value == 0xC90) { // Vol Down button on the remote
interval = interval + 50;
while (results.value == 0x290) { // Vol Down button on the remote
interval = 1000;
while (results.value == 0x16B47) { // GREEN button on the remote
digitalWrite(GREEN, HIGH);
// else if (results.value == 0xB47) { // 1 button on the remote
while (results.value == 0xB47) {
time = millis();
value = 128+127*cos(2*PI/periode*time);
value2 = 128+127*cos(2*PI/periode*(displace-time));
value3 = 128+127*cos(2*PI/periode*(testtime-time));
analogWrite(redPin, value);
analogWrite(grnPin, value2);
analogWrite(bluPin, value3);
loop();
while(results.value == 0x80B47) { // 2 button on the remote
blinkone = 1;
while (results.value == 0x40B47) { // 3 button on the remote
while (results.value == 0xC0B47) { // 4 button on the remote
while (results.value == 0x20B47) { // 5 button on the remote
while (results.value == 0xA0B47) { // 6 button on the remote
while (results.value == 0x60B47) { // 7 button on the remote
crossFade(red);
crossFade(green);
crossFade(blue);
crossFade(yellow);
crossFade(white);
crossFade(pink);
crossFade(magenta);
while (results.value == 0xE0B47) { // 8 button on the remote
while (results.value == 0x10B47) { // 9 button on the remote
while (results.value == 0x96B47 ) { // YELLOW - shut everything off. aka blackout
digitalWrite(BLUE, LOW);
digitalWrite(RED, LOW);
digitalWrite(GREEN, LOW);
blinkone = 0;
irrecv.resume();
while (blinkone == 1) { // First flash pattern. On and off
if(currentMillis - previousMillis > interval) {
previousMillis = currentMillis;
if (ledState == LOW)
ledState = HIGH;
ledState = LOW;
digitalWrite(BLUE, ledState);
} //include this
int calculateStep(int prevValue, int endValue) {
int step = endValue - prevValue; // What's the overall gap?
if (step) { // If its non-zero,
step = 1020/step; // divide by 1020
return step;
int calculateVal(int step, int val, int i) {
if ((step) && i % step == 0) { // If step is non-zero and its time to change a value,
if (step > 0) { // increment the value if step is positive...
val += 1;
else if (step < 0) { // ...or decrement it if step is negative
val -= 1;
// Defensive driving: make sure val stays in the range 0-255
if (val > 255) {
val = 255;
else if (val < 0) {
val = 0;
return val;
void crossFade(int color[3]) {
// Convert to 0-255
int R = (color[0] * 255) / 100;
int G = (color[1] * 255) / 100;
int B = (color[2] * 255) / 100;
int stepR = calculateStep(prevR, R);
int stepG = calculateStep(prevG, G);
int stepB = calculateStep(prevB, B);
for (int i = 0; i <= 1020; i++) {
redVal = calculateVal(stepR, redVal, i);
grnVal = calculateVal(stepG, grnVal, i);
bluVal = calculateVal(stepB, bluVal, i);
analogWrite(redPin, redVal); // Write current values to LED pins
analogWrite(grnPin, grnVal);
analogWrite(bluPin, bluVal);
int zag = 1;
do {
zag = zag + 1;
getIR();
while (zag < 200);
// Update current values for next loop
prevR = redVal;
prevG = grnVal;
prevB = bluVal;
void getIR() {
decode_results nresults;
I am at a dead stop. I just need it to be able to switch to different modes, even while a fade is running.
Thanks in advance!
MrKovacic:
I have been working on this and no luck..All I need is for this script to be able to pick up an IR signal and change whats its doing while its in the middle of fading..
As they say at the Pantomime "Oh yes it is !"
What have you tried whilst working on this ? Have you added some code to look for IR signals whilst the fade is going on ? The getIR function in your code looks handy judging by its name whereas the irrecv.resume doesn't, at least for getting an IR signal.
Topics merged - please don't start a new thread on a still-active topic.
You are STILL mixing GETTING a value (irrecv.decode()) with USING the value. You absolutely, positively MUST stop doing that.
// GET a value
if(irrecv.decode(&results))
IRVal = results.value;
// USE the value
if(IRVal == 0x66B47) // Blue
{ // Down here where it belong
// The rest of the cases
Declare IRVal as a long, global variable.
Pay attention to when it is appropriate to use if versus while. Almost all of your while statements should be if statements.
PaulS:
The funny part is, the original code was using IF statements.
this was the original code:
// include some junk
int RECV_PIN = 11;
int periode = 2000;
int displace = 500;
long time=0;
/* FUTURE USE
int RED1 = 2;
int GREEN1 = 3;
int BLUE1 = 4;
int RED2 = 5;
int GREEN2 = 6;
int BLUE2 = 7;
int RED3 = 8;
int GREEN3 = 9;
int BLUE3 = 10;
int RED4 = 11;
int GREEN4 = 12;
int BLUE4 = 13;
int RED = 7;
int GREEN = 6;
int BLUE = 8;
// Color arrays
int black[3] = {
0, 0, 0 };
int white[3] = {
100, 100, 100 };
int red[3] = {
100, 0, 0 };
int green[3] = {
0, 100, 0 };
int blue[3] = {
0, 0, 100 };
int yellow[3] = {
100, 100, 0 };
int pink[3] = {
0, 100, 100 };
int magenta[3] = {
100, 0, 100 };
// etc.
int prevR = redVal;
int prevG = grnVal;
int prevB = bluVal;
long chill = 2;
int blinkone = 0;
int blinktwo= 0;
int blinkthree = 0;
int blinkfour = 0;
int blinkfive = 0;
int blinksix = 0;
int blinkseven = 0;
int blinkeight = 0;
int blinknine = 0;
int val;
pinMode(8, OUTPUT);
pinMode(7, OUTPUT);
pinMode(6, OUTPUT);
if (results.value == 0x66B47) { // BLUE button on the remote
else if (results.value == 0xE6B47) { // RED button on the remote
else if (results.value == 0x490) { // Vol Up button on the remote
interval =100;
else if (results.value == 0xC90) { // Vol Down button on the remote
else if (results.value == 0x290) { // Vol Down button on the remote
interval = 1000;
else if (results.value == 0x16B47) { // GREEN button on the remote
time = millis();
analogWrite(redPin, value); // sets the value (range from 0 to 255)
analogWrite(grnPin, value2); // sets the value (range from 0 to 255)
else if (results.value == 0x80B47) { // 2 button on the remote
blinkone = 1;
else if (results.value == 0x40B47) { // 3 button on the remote
else if (results.value == 0xC0B47) { // 4 button on the remote
else if (results.value == 0x20B47) { // 5 button on the remote
else if (results.value == 0xA0B47) { // 6 button on the remote
else if (results.value == 0x60B47) { // 7 button on the remote
crossFade(red);
crossFade(green);
crossFade(blue);
crossFade(yellow);
crossFade(white);
crossFade(pink);
crossFade(magenta);
else if (results.value == 0xE0B47) { // 8 button on the remote
else if (results.value == 0x10B47) { // 9 button on the remote
else if (results.value == 0x96B47 ) { // YELLOW - shut everything off. aka blackout
blinkone = 0; // stops that pesky blue light from blinking
irrecv.resume();
if (blinkone == 1) { // First flash pattern. On and off
ledState = HIGH;
ledState = LOW;
} //include this
return step;
val += 1;
val -= 1;
if (val > 255) {
val = 255;
else if (val < 0) {
val = 0;
return val;
// Convert to 0-255
int zag = 1;
do {
zag = zag + 1;
getIR();
while (zag < 200);
prevR = redVal;
prevG = grnVal;
prevB = bluVal;
void getIR() {
UKHeliBob:
MrKovacic:
I did try, but it seems like te piece of code actually doing the math acts like a delay, so the Ir rec pin will ignore what it sees. I am hoping to use the yellow button as a 'stop all' type feature. Using the blink without delay, I can interupt a standard blink, but I cant seems to slide a chunk of code into that fade. It seems like the fade either wont loop (runs through one cycle), or it will not run at all, Or.. it will continue to run ignoring any other button press I do.
If you don't insert the code to look for an IR signal the loop is not going to exit, is it ?
As a matter of interest, why all the maths ? Will statements like these always give a result between 0 an 255 ?
You've ignored my comment about getIR not doing anything useful. It's nice to format the code, but don't overlook the comments about the code itself.
It looks to me like you are calling getIR inside the loop which fades LEDs, so having it work properly would be helpful.
I'm not ignoring the comments, I was just mentioning that I was going back and forth between using IF statements and While statements. Doesn't seem to be much difference, except the IF statements work better. I can try to move the detection portion of the code to a function, then just call that function. The only thing I am having trouble with is, when I press a button on the remote, it seems like it continues with the fade math. Almost like by the time the entire code from the remote has been transmitted, the Arduino is already past the function to look for code, and is back handling math for the fade. I am wondering if it is possible at all to have it fade some LEDs and at the same time, keep an eye on the IR_RCV pin waiting for a button press.
UKHeliBob:
If you don't insert the code to look for an IR signal the loop is not going to exit, is it ?As a matter of interest, why all the maths ? Will statements like these always give a result between 0 an 255 ?
value2 = 128+127cos(2PI/periode*(displace-time));
value3 = 128+127cos(2PI/periode*(testtime-time));
To be honest, i am not 100% sure. I know it is a small fader for the LEDs. I have 2 faders, one I can customize nicely, and this one.
In the future, I hope to make a few scripts to blink LEDs to react to sound, but different settings.
It seems to me that one of the problems for you and those trying to help is that the current sketch is complicated to understand in its own right without trying to shoehorn reading the IR into it. There is a lot going on in the sketch and I for one cannot see the wood for the trees. For instance, the crossFade function is called with a parameter of color[3] but the color array is not defined in the sketch nor is there any attempt to use the value of color[3] in the function. Needless to say the sketch will not compile.
I would suggest that you start with a much simpler sketch, get it working then add to it. How about a sketch to respond to button presses to turn on or off a single LED ? In my experience there is a world of difference between trying to understand and modify a program written by someone else and writing one yourself.
UKHeliBob:
It seems to me that one of the problems for you and those trying to help is that the current sketch is complicated to understand in its own right without trying to shoehorn reading the IR into it. There is a lot going on in the sketch and I for one cannot see the wood for the trees. For instance, the crossFade function is called with a parameter of color[3] but the color array is not defined in the sketch nor is there any attempt to use the value of color[3] in the function. Needless to say the sketch will not compile.I would suggest that you start with a much simpler sketch, get it working then add to it. How about a sketch to respond to button presses to turn on or off a single LED ? In my experience there is a world of difference between trying to understand and modify a program written by someone else and writing one yourself.
This script is more of a Frankenstein. Parts of it were inspired from other code. I am going to explore using a pin change interrupter to do the dirty work of the yellow button which is, for the time being, my all stop button. Because I have no formal or book training, I write code based on my thought pattern which is much like RAM on any computer, all over the place.
I will explore other options and start a new thread with simpler easier to understand code if I get stuck. Thanks!
int zag = 1;
do {
zag = zag + 1;
getIR();
while (zag < 200);
There is nothing in that loop (from 0 to 1020) that leaves the loop early (if you press a button on the remote or for any other reason). You need to address that first.
int zag = 1;
do {
zag = zag + 1;
getIR();
while (zag < 200);
What does that do? It gets the IR remote value 199 times. Why? Why not once?
void getIR() {
You are making a second instance of irrecv (the first being global) which is then immediately destroyed. The value nresults is not used anywhere.
Since I don't know or dont fully understand how to get it to check for that push in t he middle of a fade. I decided to try an interupt, which did not help. Here is the new code, and I cleaned it up using AutoIT Cleaner:
Any thoughts would be greatly appreciated
int pbIn = 0;
volatile int state = LOW;
int RECV_PIN = 11;
int periode = 2000;
int displace = 500;
long time =0;
/* FUTURE USE
int RED1 = 2
int GREEN1 = 3
int BLUE1 = 4
int RED2 = 5
int GREEN2 = 6
int BLUE2 = 7
int RED3 = 8
int GREEN3 = 9
int BLUE3 = 10
int RED4 = 11
int GREEN4 = 12
int BLUE4 = 13
int redPin = 7;
int grnPin = 6;
int bluPin = 8;
int value, value2, value3;
int RED = 7;
int GREEN = 6;
int BLUE = 8;
// Color arrays
int black[3] = { 0, 0, 0 };
int white[3] = { 100, 100, 100 };
int red[3] = { 100, 0, 0 };
int green[3] = { 0, 100, 0 };
int blue[3] = { 0, 0, 100 };
int yellow[3] = { 100, 100, 0 };
int pink[3] = { 0, 100, 100 };
int magenta[3] = { 100, 0, 100 };
// etc.
int prevR = redVal;
int prevG = grnVal;
int prevB = bluVal;
long chill = 2;
int ledState = LOW;
int blinkone = 0;
int blinktwo = 0;
int blinkthree = 0;
int blinkfour = 0;
int blinkfive = 0;
int blinksix = 0;
int blinkseven = 0;
int blinkeight = 0;
int blinknine = 0;
int val;
void setup(){
attachInterrupt(pbIn, CheckYellow, HIGH);
pinMode(8, OUTPUT);
pinMode(7, OUTPUT);
pinMode(6, OUTPUT);
interval =100;
interval = 1000;
time = millis();
blinkone = 1;
crossFade(red);
crossFade(green);
crossFade(blue);
crossFade(yellow);
crossFade(white);
crossFade(pink);
crossFade(magenta);
blinkone = 0;
if (ledState == LOW);
ledState = HIGH;
else{
ledState = LOW;
} //include this
step = 1020/step;
return step;
val += 1;
val -= 1;
if (val > 255) {
val = 255;
else if (val < 0) {
val = 0;
return val;
void CheckYellow() {
loop();
// Convert to 0-255
void getIR() {
I have also tried setting the function like this:
void getIR() {
if (irrecv.decode(&results)){
loop();
and tried
void getIR() {
loop();
and putting
getIR();
in various places in the fade function. The only 2 things that happen are either the fade doesnt work at all, or it works fine but refuses to stop for the yellow button.
