Topic: ZERO using timer and DMA to drive DAC (Read 2039 times) previous topic - next topic
mantoui
Here is a simple proof of concept of using TCC0 timer to drive DAC from circular DMA buffer.
https://github.com/manitou48/ZERO/blob/master/dacdma.ino
The sketch uses the PWM timer TCC0 on pin 12 (not used), and then overrides the frequency and duty cycle.  A circular buffer of 128 half-words is used by the DMA to fill the DAC on each timer tick.  Example can use sawtooth or sine wave in buffer.
Verified with scope.
AloyseTech
electro_95
Thanks as always for these useful examples.  I'm trying to adapt this to use the DMA to copy cc0 each time that the TCC0 MC1 interrupt occurs.
