Topic: MKR1000 posting to Firebase: time (Read 927 times) previous topic - next topic
tomasgf
I am prototyping a device that will check values from force sensitive resistor (FSR) sensors and post their values to Firebase.
At the moment I am testing it with 1 sensor and it works, the value is posted to Firebase.
The problem I have is that the WiFiSSLClient blocks the loop for more than a second… If the FSR is pressed again during that time, that measure is ignored (which is not ideal).
One of the functions has a delay(200) - not 1000 - and without it, the data doesn't get posted.
Can you suggest any improvement on the code?
Code: [Select]
   //read sensor on pin A0:
  int sensorValue = analogRead(fsrAnalogPin);
  // check if it's higher than the current peak:
  if (sensorValue > peakValue) {
    peakValue = sensorValue;
  if (sensorValue <= threshold - noise ) {
    if (peakValue > threshold + noise) {
      // 1. Detect that you have a peak value:
      Serial.print("peak: ");
      Serial.println(peakValue);
      // 2. Capture this value to send it out
      fsrSqueezed = true;
      howMany++;
      Serial.print("Squeeze count: ");
      Serial.println(howMany);
      fsrOutReading = peakValue;
      fsrLastSqueeze = millis();
      // reset the peak value:
      peakValue = 0;
  if (fsrSqueezed == true) {
    digitalWrite(LEDpin, HIGH);
    Serial.print("squeeze value: ");
    Serial.println(fsrOutReading);
    // 3. Send record to Firebase
    sendToFirebase(fsrOutReading); // This call stops the loop for more than 1 second…
    Serial.print("Time diff:");
    Serial.println(millis() - fsrLastSqueeze);  // This value gets ~1200 milliseconds!!!
    digitalWrite(LEDpin, LOW);
    fsrSqueezed = false;
void sendToFirebase(int fsrReading) {
  if (client.connect(HOST, 443)) {
    sendData(fsrReading);
    client.stop();
void sendData(int pressure) {
  // Creating the pathBuffer
  sprintf(pathBuffer, "POST %s.json?auth=%s HTTP/1.1", PATH, SECRET);
  int size = constructJson(WiFi.getTime(), pressure);
  client.println(pathBuffer);
  client.print("Host: ");
  client.println(HOST);
  client.println("Content-Type: application/json");
  client.print("Content-Length: ");
  client.println(size);
  client.println("Accept: application/json");
  client.println("Connection: close");
  client.println();
  client.println(bodyBuffer);
  delay(200);
