C:\Arduino-1.0\hardware/tools/avr/bin/avrdude -CC:\Arduino-1.0\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega1284p -cusbasp -Pusb -Uflash:w:C:\Arduino-1.0\hardware\mighty-1284p\bootloaders\optiboot\optiboot_atmega1284p.hex:i -Ulock:w:0x0F:m
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Arduino-1.0\hardware/tools/avr/etc/avrdude.conf"
Using Port : usb
Using Programmer : usbasp
avrdude: seen device from vendor ->www.fischl.de<-
avrdude: seen product ->USBasp<-
AVR Part : ATMEGA1284P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 128 0 no 4096 8 0 9000 9000 0xff 0xff
flash 65 10 256 0 yes 131072 256 512 4500 4500 0xff 0xff
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : usbasp
Description : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9705
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Arduino-1.0\hardware\mighty-1284p\bootloaders\optiboot\optiboot_atmega1284p.hex"
avrdude: writing flash (130556 bytes):
Writing | ################################################## | 100% 73.06s
avrdude: 130556 bytes of flash written
avrdude: verifying flash memory against C:\Arduino-1.0\hardware\mighty-1284p\bootloaders\optiboot\optiboot_atmega1284p.hex:
avrdude: load data flash data from input file C:\Arduino-1.0\hardware\mighty-1284p\bootloaders\optiboot\optiboot_atmega1284p.hex:
avrdude: input file C:\Arduino-1.0\hardware\mighty-1284p\bootloaders\optiboot\optiboot_atmega1284p.hex contains 130556 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 70.54s
avrdude: verifying ...
avrdude: 130556 bytes of flash verified
avrdude: reading input file "0x0F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x0F:
avrdude: load data lock data from input file 0x0F:
avrdude: input file 0x0F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.00s
avrdude: 1 bytes of lock verified
avrdude done. Thank you.
Now an LED on D0 (pin 1) flashes quickly three times on a reset, nothing more.
When I try to download a simple sketch, via FTDI Basic to the serial ports, it is not working.
byte outputPin = 0;
void setup(){
pinMode (outputPin, OUTPUT);
void loop (){
digitalWrite (outputPin, HIGH);
delay (500);
digitalWrite (outputPin, LOW);
delay (500);
red text from the sketch download message
Using Port : \\.\COM22
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Programmer Type : Arduino
Description : Arduino
avrdude: Send: A [41] . [80] [20]
avrdude: Recv: . [03]
avrdude: Send: A [41] . [81] [20]
avrdude: Recv: . [04]
avrdude: Send: A [41] . [82] [20]
avrdude: Recv: . [05]
avrdude: Send: A [41] . [98] [20]
Hardware Version: 3
Firmware Version: 4.5
avrdude: Send: A [41] . [84] [20]
avrdude: Send: A [41] . [85] [20]
avrdude: Send: A [41] . [86] [20]
avrdude: Recv:
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x41
avrdude: Send: A [41] . [87] [20]
avrdude: Recv:
avrdude: Send: A [41] . [89] [20]
avrdude: Recv:
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 1.607 Hz
SCK period : 2487621.6 us
avrdude: Recv:
avrdude: Recv:
avrdude: Send: B [42] . [82] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [01] . [00] . [10] . [00] . [00] . [02] . [00] . [00] [20]
avrdude: Recv:
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x42
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: Send: Q [51] [20]
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
@Crossroads ...
If you would like a special version of Optiboot that blinks a LED on a particular port, just let me know. I pulled down the source and built myself one this morning.
system
February 12, 2012, 1:05am
121
retrolefty:
My 1284TH board may very well remain unpopulated (but still appreciated) if the instructions steps for modifying arduino IDE 1.0 aren't avalible in a listed sequence of single steps and written in English.
Well, this is your opportunity to help improve things. What about the instructions in this readme are too difficult?
# Mighty 1284P: Platform files for Arduino to run on ATmega1284P
## What is it?
Everything you need to run Arduino on ATmega1284P.
## Current state
Everything is here and has been initially tested. It should work fine. There is more detailed testing which must be completed before calling it completely 'done' though.
The platform now includes optiboot. This bootloader is better in every way than the previous version, so it is recommended in all cases. The prior one is included for reference.
## Installation
1. Download the [ZIP File](https://github.com/maniacbug/mighty-1284p/zipball/master)
2. Unzip it a folder called 'hardware' off your sketches directory, e.g. /Users/maniacbug/Source/Arduino/hardware/mighty-1284p
3. Restart the IDE
4. Select Tools > Board > Mighty 1284p 16MHz using Optiboot
5. To burn the bootloader, follow the Arduino [Bootloader](http://arduino.cc/en/Hacking/Bootloader) instructions.
This file has been truncated. show original
Any idea why I'm getting this download error?
Hardware Version: 3
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: Send: E [45] . [05] . [08] . [d7] . [a0] . [00] [20]
avrdude: Send: P [50] [20]
Reading | avrdude: Send: u [75] [20]
avrdude: Recv: . [14] . [1e] . [97] . [05] . [10]
avrdude: Send: V [56] . [a0] . [0f] . [fc] . [00] [20]
avrdude: Recv: . [00]
avrdude: Send: V [56] . [a0] . [0f] . [fd] . [00] [20]
avrdude: Send: V [56] . [a0] . [0f] . [fe] . [00] [20]
avrdude: Send: V [56] . [a0] . [0f] . [ff] . [00] [20]
avrdude: reading input file "C:\Users\Owner\AppData\Local\Temp\build4804581199518263256.tmp\IO_test.cpp.hex"
avrdude: writing flash (1194 bytes):
Writing | avrdude: Send: U [55] . [00] . [00] [20]
avrdude: Recv:
avrdude: stk500_loadaddr(): (a) protocol error, expect=0x14, resp=0x55
avrdude: Send: d [64] . [01] . [00] F [46] . [0c] . [94] . [85] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [c4] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [0c] . [94] . [a5] . [00] . [00] . [00] ! [21] . [00] $ [24] . [00] ' [27] . [00] * [2a] . [00] . [00] . [00] " [22] . [00] % [25] . [00] ( [28] . [00] + [2b] . [00] . [00] . [00] [20] . [00] # [23] . [00] & [26] . [00] ) [29] . [00] . [02] . [02] . [02] . [02] . [02] . [02] . [02] . [02] . [04] . [04] . [04] . [04] . [04] . [04] . [04] . [04] . [03] . [03] . [03] . [03] . [03] . [03] . [03] . [03] . [01] . [01] . [01] . [01] . [01] . [01] . [01] . [01] . [01] . [02] . [04] . [08] . [10] [20] @ [40] . [80] . [01] . [02] . [04] . [08] . [10] [20] @ [40] . [80] . [01] . [02] . [04] . [08] . [10] [20] @ [40] . [80] . [01] . [02] . [04] . [08] . [10] [20] @ [40] . [80] . [00] . [00] . [00] . [01] . [02] . [00] . [08] . [09] . [00] . [00] . [00] . [00] . [04] . [03] . [07] . [06] . [00] . [00] . [00] . [00] . [00] . [00] [20]
avrdude: Recv:
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x64
avrdude: Send: V [56] @ [40] . [00] . [00] . [0c] [20]
avrdude: Recv:
avrdude: stk500_cmd(): programmer is out of sync
system
February 12, 2012, 1:19am
123
You're getting out-of-sync's in 2 different places. No idea. Hoping @westfw takes a look and maybe he has some insight.
Wonder if it's some Windows-specific issue. I know westfw uses Mac and I use Ubuntu. @skyjumper do you use Windows?
But I did get the right bootloader installed, yes? 3 Quick flashes on reset, then no more?
maniacbug:
retrolefty:
mighty-1284p/README.md at master · maniacbug/mighty-1284p · GitHub
Wow MB, looks like very complete instructions. I down loaded and unzipped to my arduino 1.0 sketch folder/hardware folder. Launched arduino 1.0 and the boards menu now shows five new 1284 based boards. Not sure what the second board choice (avr-developers.com .....) means? I understand that one has a choice of using optiboot or older 'mega type' bootloader, I suspect I will go with the optiboot when the time comes. I complied the blink sketch with no errors.
Which 1284 board choice will be most applicable for Bob's new 1284TH board, or is that still being worked out for the pin mapping thingee?
Nice you noted not to use USBtiny programmer as that is what I normally use. No problem I will just use arduionISP sketch.
skyjumper, shoot me a copy. kinda frustrating that I can't get this working in Windows Vista in 1.0 when I did all those boards under -0022.
I can't make -0022 work either. Wondering if this breadboard setup is any good.
system
February 12, 2012, 6:05am
128
retrolefty:
Thanks... This points out that the readme should explain the boards, so I added this:
## Supported Boards
* 'Mighty 1284p 16MHz using Optiboot'. The main board. Use this unless you have some clear reason to use another board. This uses a straightforward pinout that is especially helpful on a breadboard-built unit.
* 'avr-developers.com pinouts 16MHz using Optiboot'. Some people prefer the pinouts from avr-developers.com. The classic pinouts.
* 'Bobuino'. CrossRoads' board built for maximum compatibility with Arduino Uno-class shields.
* 'Original Mighty 1284p 16MHz'. The very first bootloader I ever got working. Not recommended for use, but here as historical record.
* 'Original Mighty 1284p 8MHz'. Ditto, but runs at 8MHz.
And obviously from that, the "Bobuino" is the appropriate board selection for the 1284TH board.
I was gonna wirewrap up a quick test board to convince myself the bootloader/serial loaders all work together since I can't seem to get this breadboard version to work and I don't have PCBs yet - and not a single wirewrap pin in the house!
Must have used up what I had. Gave some to a college friend too - might have cleaned myself out by accident.
Gonna order a bunch more, researching here what else I might stock up on:
http://www.king-cart.com/phoenixent/frontpage=yes
What I'd really like is some ribbon cable to 0.1" spaced male pins to plug into female headers.
They have individual pins too
HWS4615 2.6cents each - cheaper to get a strip of 40 tho.
Or these low profile numbers to make your board lower profile
HWS5470 7 cents
HWS5356 94 cents
makes for a pricey 40 pin socket tho compared to an 87 cent strip of 40 pins.
HWS15590
CrossRoads:
I'd like some of that too, but I have not been able to find it!
CrossRoads:
A copy of Optiboot? No problem. Sorry it took a while, Kelly and I were out late last night. I'll email it direct to you.
I use Arduino 1.0 and 0.22 on Windows 7 64bit.
skyjumper:
CrossRoads:
I bought these "not sure if it is the same person" ribbon jumpers from ebay then, I cut the plastic off of one end and soldered a header male pin into it. It is a bit of a pain but makes a nice jumper.
http://www.ebay.com/itm/F01968-30cm-40-WAY-Rainbow-Color-Flat-Arduino-Jumper-Cable-home-appliance-/270861063078?pt=Radio_Control_Parts_Accessories&hash=item3f1093d3a6
Think you can just pop the pin out of the 1x1 header and plug it into a 1x8 (or 1x9 for 7 segment display with DP and power), be less work.
http://www.pololu.com/catalog/product/1931
I may just get ribbon cable & crimp on connectors to plug into housings. Then can make it any length I want.
I just don't understand why its so hard to find .1 in 4 or 5 conductor ribbon cable Oh well...
No demand I guess.
No IDC connectors either. Everything appears to be for turning flat 0.05" ribbon into dual row 0.1" .
I'm in the middle of ordering a bunch of crimp connectors, housings, female headers, and a crimper from pololu.com .
Not sure where I'll get the ribbon cable from yet.
CrossRoads:
No demand I guess.
Jameco was where we use to always ordered out ribbon cable and IDC connectors:
http://www.jameco.com/webapp/wcs/stores/servlet/StoreCatalogDrillDownView?langId=-1&storeId=10001&catalogId=10001&freeText=ribbon&refine=1&history=1hn020t6|subCategoryName~Wire%2B%2526%2BCable^category~25^categoryName~category_root^prodPage~15^page~SEARCH%252BNAV
