I am in the throes of converting to Mega 2560 at the moment and modifying my proto boards. The cosm feed I have at the moment does not use the SD or a clock since it only needs them for backup when in a remote location.
Here is what I'm working on - untested. This is for Uno and is simply the cosm stuff I had added to a previous sketch that worked fine.
Note that I don't use strings for the serial and SD feeds, hence the slightly bloated code, but it works.
Mega pins are different but it should not affect the code.
I have had serial print stuff looking like yours and it was down to sending it too fast but the code you sent me had the serial at 9600 so maybe you need a couple of delays in it. The 85 could be the DS18B20s being read too soon.
From cosm library example and lifts from a lot of others
particularly from Stanley in Kuala Lumpur.
Use your own DS18B20 addresses, keys etc.
//#include <LiquidCrystal.h>
#include <SD.h>
#include <string.h>
#include "RTClib.h"
RTC_DS1307 RTC;
File myFile;
char filename[] = "00000000.CSV";
#include "Wire.h"
#define DS1307_ADDRESS 0x68
#include <OneWire.h>
#include <DallasTemperature.h>
#include <SPI.h>
#include <Ethernet.h>
#include <HttpClient.h>
#include <Cosm.h>
byte InThermo[8] =Â {
 0x28, 0x69, 0xC2, 0xB0, 0x03, 0x00, 0x00, 0X9F};
byte OutThermo[8] = {
 0x28, 0x7A, 0x8B, 0xC0, 0x03, 0x00, 0x00, 0x2F};
#define ONE_WIRE_BUS 3
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
byte mac[] = {
 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char cosmKey[] = "l6absmJ.................U0t0Zz0g";
int sensorPin = 3;
int second, minute, hour, weekDay, monthDay, month, year;
float InTemp, OutTemp;
// Define the strings for our datastream IDs
char sensorId0[] = "InThermo";
char sensorId1[] = "OutThermo";
//char sensorId2{} = "DrainThermo"
const int bufferSize = 100;
char bufferValue[bufferSize]; // enough space to store the string we're going to send
CosmDatastream datastreams[] = {
 CosmDatastream(sensorId0, strlen(sensorId0), DATASTREAM_FLOAT),
 CosmDatastream(sensorId1, strlen(sensorId1), DATASTREAM_FLOAT),
 //  CosmDatastream(sensorId2, strlen(sensorId2), DATASTREAM_FLOAT),
// Finally, wrap the datastreams into a feed
CosmFeed feed(83153, datastreams, 2 /*put your number here */);
EthernetClient client;
CosmClient cosmclient(client);
//LiquidCrystal lcd(8,9,56,5,6,7);
 Wire.begin();
 delay(300);//Wait for newly restarted system to stabilize
 Serial.print("Temperature measurement");
 Serial.print("Initializing SD card...");
 pinMode(10, OUTPUT);
 if (!SD.begin(4)) {
  Serial.println("initialization failed!");
  return;
 Serial.println("initialization done.");
 sensors.setResolution(InThermo, 12);
 sensors.setResolution(OutThermo, 12);
 Serial.println("Starting multiple datastream upload to Cosm...");
 Serial.println();
 while (Ethernet.begin(mac) != 1)
  Serial.println("Error getting IP address via DHCP, trying again...");
  delay(10000);
 GetClock();
 PrintDate;
 sensors.requestTemperatures();
 Serial.println("Read sensor value ");
 InTemp = (sensorValue(InThermo));
 OutTemp = (sensorValue(OutThermo));Â
 // float Drain = (sensorValue(DrainThermo));Â
 datastreams[0].setFloat(InTemp);
 datastreams[1].setFloat(OutTemp);
 Serial.println(datastreams[0]);
 Serial.println(datastreams[1]);
 datastreams[2].setFloat(DrainTemp);
 Serial.println(datastreams[2].getFloat(DrainTemp));
 // LCD stuff will go here
 if (second == 0 || second == 10 || second == 20 || second == 30 || second == 40 || second == 50)
  myFile = SD.open("data.csv", FILE_WRITE);//<<<<<<<<<<<<< OPEN
  WriteSD;
  int ret=0;
  delay(200);// Delay... must not be too short.
  Serial.println("Uploading it to Cosm");
  ret = cosmclient.put(feed, cosmKey);  // SEND FEED TO COSM
  Serial.print("cosmclient.put returned "); // tell us about it
  Serial.println(ret);           // pray to God it says 200
  myFile.println();
  myFile.close();//>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>CLOSE
  Serial.println();
  delay(800);
//sensorValue function
float sensorValue (byte deviceAddress[])
 float tempC = sensors.getTempC (deviceAddress);
 return tempC;
byte bcdToDec(byte val)Â {
 // Convert binary coded decimal to normal decimal numbers
 return ( (val/16*10) + (val%16) );
void GetClock(){
 // Reset the register pointer
 Wire.beginTransmission(DS1307_ADDRESS);
 byte zero = 0x00;
 Wire.write(zero);
 Wire.endTransmission();
 Wire.requestFrom(DS1307_ADDRESS, 7);
 second = bcdToDec(Wire.read());
 minute = bcdToDec(Wire.read());
 hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
 weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
 monthDay = bcdToDec(Wire.read());
 month = bcdToDec(Wire.read());
 year = bcdToDec(Wire.read());
void PrintDate () {
 Serial.print(monthDay);
 Serial.print("/");
 Serial.print(month);
 Serial.print("/");
 Serial.print(year);
 Serial.print("  ");
 Serial.print(hour);
 Serial.print(":");
 Serial.print(minute);
 Serial.print(":");
 if (second < 10)
  Serial.print("0");
 Serial.print(second);
 Serial.print("    ");
void WriteSD () {
 myFile.print(monthDay);
 myFile.print("/");
 myFile.print(month);
 myFile.print("/");
 myFile.print(year);
 myFile.print(", ");
 myFile.print(hour);
 myFile.print(":");
 myFile.print(minute);
 myFile.print(":");
 myFile.print(second);
 myFile.print(",    ");
 myFile.print(InTemp);
 myFile.print(",  ");
 myFile.print(OutTemp);
 myFile.print(",  ");
