Hmmmmm...
What voltage are you trying to generate? I see you have a 22 ohm load, which would take more than 1/2 amp even at 12v in with no switching at all. ( 0.54A ignoriig the the diode drop for now
As Leo says , the 14002 isnt quick enough. And given my sums below, perhaps totally inadequate in current rating.
And you really need a complementary drive for the output device. A typical gate capacitance is ~3nF, which gives a 6uS drive risetime which is slow, and could give bad switching losses at high drive frequencies . And there's no mechanism for controlling the output voltage.
And the capacitors look far too small - depends on you switching frequency.
THE BASICS :
If you're driving this with an arduino PWM output the frfequency would be about 1kHz.
With a 50% duty cycle the current at the end of the 'on' part would be given by :
. V = L di/dt..
The on time = (1/2)/1000 => 500uS
so di/dt is 12/330u => ~ 36,000 v/s => about 18 Amps
and the energy stored
E = 1/2 L I^2 => 53mJ. At 1kHz frequency this gives 53j/s or 53 watts.
With a 22 ohm load this would mean the max voltage you'd reach is about 25 volts.
With a 99% duty cycle you get
Max current 35 amps, max power 105 watts, max voltage 35 volts.
A 35 amp 330u inductor is a pretty juicy lump ! If you're not using a big enough inductor it would saturate in less than 500uS. When this happens trhe inductance drops to effectively zero, and the rate at which the current rises is limited only by the circuit resistances = > a LOT! of current.
You can buy excellent switchmode power supplies from many people - either as completed units or as clever ICs from many people... unless your requirements are really weird I'd go that way.
I built a capacitor discharge ignition unit once, and got about 250V out of such a circuit - that used a 555 timer as drive to the switching FET and a feedback circuit to control the output voltage - that IS pretty weird!
What's your application.. ?
Look at LT's excellent application notes for a much more detailed analysis of switchmode power circuits.
regards
Allan.
