Arduino Zero support is available through Boards Manager.
We also have a new editor, a serial monitor that stays open (disabled) while uploading, and a File > Open Recent menu showing the last 5 opened sketches.
C:\Program Files (x86)\arduino-1.6.5>arduino_debug
Loading configuration...
Initializing packages...
Preparing boards...
java.io.FileNotFoundException: C:\Users\Ren?\AppDat
es.txt (Zugriff verweigert)
at java.io.FileOutputStream.open0(Native Me
at java.io.FileOutputStream.open(FileOutput
at java.io.FileOutputStream.(FileOutp
at processing.app.legacy.PApplet.createWrit
at processing.app.PreferencesData.save(Pref
at processing.app.Base.(Base.java:343
at processing.app.Base.guardedMain(Base.jav
at processing.app.Base.main(Base.java:137)
java.lang.RuntimeException: Couldn't create a write
oaming\Arduino15\preferences.txt
When I start the exe directly as an administrator then the ide starts. Must be a problem with permissions.
Indeed. You may have run the IDE as administrator the first time you started it. Please ensure your user has access to folder %APPDATA%\Arduino15. Or, if you don't care about losing your preferences, just trash it and restart the IDE
The problem is not resolved by deleting the folder "% APPDATA% \ Arduino15"
A new folder is not created. Arduino 1.6.5 will start only when it is called as an administrator.
I have several old versions of Arduino installed which all work and i can not imagine why the% APPDATA% folder should be the problem therefore. I will now have to try on my notebook (Windows 7 64Bit)
I'm experiencing the same issue on W7 64 SP1 and stand-alone installation (ie .zip file).
Same problem if started as admin
On the same machine IDE 1.6.4 works fine.
The splash screen suddenly close without any error message or code.
Trying debug exe but cmd windows close also immediatly and so, no debug message available.
Hello, I have a problem opening directly from ".ino" file, it doesn't open.
Windows 8.1 x64 and Arduino IDE previous versions OK.
Tried to delete the old preferences, upgrading the IDE, deleting the /user/appdata/roaming/arduino15/ and fresh install after reboot.
IDE Launch when calling Arduino or Arduino_debug but nothing when called from ino or pde file.
Returned error from Arduino_debug is : "Erreur : impossible de trouver ou charger la classe principale processing.app.Base" (error: can't find or load the main class processing.app.Base).
Admin or not give the same.
Alomamabobo .ino file association (what makes double clicking on .ino file possible) is done by the installer: have installed the IDE or just unzipped it?
Installer only and tried with arduino & arduino_debug ( tried file association: .ino -> arduino and .ino -> arduino_debug)
Thanks for the answer.
Edit: tried to put (overwrite) everything from the zip file to the installed directory (C:\Program Files (x86)\Arduino) same result.
File open from IDE work as expected. Still can't open file directly.
We found a bug with the windows .exe files that prevents double clicking a .ino from opening the IDE. We are going to deliver a 1.6.5-r2 for windows later tomorrow
It works great on Win7 32bit. But when I double-click a .ino file, it opens with 1.6.1. I installed 1.6.5 as a zip and 1.6.1 with the installer. But I want the default IDE to be 1.6.5. How can I change this? Should I uninstall 1.6.1?
Isaac96, yes, you need to install 1.6.5 with the installer. However, please wait for the release of 1.6.5-r2 (later tomorrow) as we have found a bug that prevents double clicking from opening the IDE
If you have unconventional characters in your username, the installer will create a new %appdata% folder with the wrong username.
It's a common mistake from years back that non-english users seems to have to relive again and again.
My name and username is "Håkan" and the appdata folder should be created in "users\Håkan\appdata\roaming\Arduino15" but is created in "users\H†kan\appdata\roaming\Arduino15"
This is obviously something that needs to be fixed in the new installation!
