manual says:
mclk/1024*1/255 is the slowest clock == 84000000/1024/255==321.69....HZ
theoreticaly the longest period should be 321.7/65535 =.00491.... hz or 203sec/ pulse...
i dislike the clock setting function / you may have better luck seting it explitistly from the associated values (Find your own dividers & send them to the function )
hook a led(& resistor) to pin 9 & try the code below
This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;
#define PWM_CHANNEL_0 0
#define PWM_CHANNEL_4 4
#define PWM_CHANNEL_5 5
#define PWM_CHANNEL_6 6
int period =2;
void
startTimer (Tc * tc, uint32_t channel, IRQn_Type irq, uint32_t frequency)
pmc_set_writeprotect (false);
pmc_enable_periph_clk ((uint32_t) irq);
TC_Configure (tc, channel,
TC_CMR_WAVE | TC_CMR_WAVSEL_UP_RC |
TC_CMR_TCCLKS_TIMER_CLOCK4);
uint32_t rc =
(VARIANT_MCK / 128 / frequency) > 2 ? (VARIANT_MCK / 128 / frequency) : 2;
//128 because we selected TIMER_CLOCK4 above
TC_SetRA (tc, channel, rc / 2); //50% high, 50% low
TC_SetRC (tc, channel, rc);
TC_Start (tc, channel);
tc->TC_CHANNEL[channel].TC_IER = TC_IER_CPCS;
tc->TC_CHANNEL[channel].TC_IDR = ~TC_IER_CPCS;
NVIC_EnableIRQ (irq);
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
startTimer(TC1, 0, TC3_IRQn, 1);
//PWM config
pmc_enable_periph_clk(ID_PWM);
PWMC_DisableChannel(PWM, PWM_CHANNEL_4);
PWMC_ConfigureClocks(VARIANT_MCK/1024 /255, 0, VARIANT_MCK);
int ulPin = 9;
// Setup PWM for this pin
PIO_Configure(g_APinDescription[ulPin].pPort,
g_APinDescription[ulPin].ulPinType,
g_APinDescription[ulPin].ulPin,
g_APinDescription[ulPin].ulPinConfiguration);
//***************Channel 4
PWMC_ConfigureChannel(
(Pwm*) PWM, // pPwm,
(uint32_t) PWM_CHANNEL_4 , // ul_channel,
(uint32_t) PWM_CMR_CPRE_CLKA , // prescaler,
(uint32_t) 0 , // alignment, 0=left alighned
(uint32_t) 0 ); // polarity )
PWMC_SetPeriod(
(Pwm*) PWM, //pPwm,
(uint32_t) PWM_CHANNEL_4,//ul_channel,
(uint16_t) period
PWMC_SetDutyCycle(
(Pwm*) PWM ,//pPwm,
(uint32_t) PWM_CHANNEL_4,// ul_channel,
(uint16_t) period/2 //duty
PWMC_EnableChannel(
(Pwm*) PWM, //pPwm,
(uint32_t) PWM_CHANNEL_4// ul_channel
//*******************************************************8
volatile boolean l;
// This function is called every 1 sec.
void TC3_Handler()
// You must do TC_GetStatus to "accept" interrupt
// As parameters use the first two parameters used in startTimer (TC1, 0 in this case)
TC_GetStatus(TC1, 0);
digitalWrite(led, l = !l);
period < 4 ? period = 4:period =period << 1;
period >65536 ? period = 4 :period;
PWMC_SetPeriod(
(Pwm*) PWM, //pPwm,
(uint16_t) period-1
PWMC_SetDutyCycle(
(Pwm*) PWM ,//pPwm,
(uint16_t) PWM->PWM_CH_NUM[4].PWM_CPRD/2 //duty
// the loop routine runs over and over again forever:
Serial.println( PWM->PWM_CH_NUM[4].PWM_CPRD);
