Is Arduino or Atmel interested in Linux users? Or are we being pushed to the back burner? I have challenged Atmel to show up here, and see what is happening with their latest 8-bit compiler. Let's see what they do!
BTW, I do not believe the problem with Linux is Arduino. I firmly believe this is an Atmel challenge, and I am hoping that Arduino can put more pressure on Atmel than I can.
As far as I know there are a lot of Linux Arduino users out there - since the Arduino software is open source, designed to be portable, packaged for download for 3 OS's I guess Arduino cares too..
Hey, I've been using linux since 4 years (work and home) and doing Arduino stuff since a year and never had a problem at all. When something fails is programmer's issue, not hardware nor compiler. I have a ethernet shield, used a lot of sensors, displays and more and everything worked well. Not to be afraid
I also just use linux it is more easy to deal on arduino, better fast compiling and upload code and dont give stupid errors when change usb port like windows.
I realy hate windows it is just a big disapointeness.I prefer MAC and linux
If you trie it is like drive a fiat and then change to a ferrari:)
This is a programmer's issue. Atmel's programmer's issue. The newest release will not compile anything if not modified. Period.
Not only does it not, but the way it is coded, it shouldn't. Trying to force it to compile will only generate faulty code. I had to make two modifications to get it to compile at all. And relatively easy bugs to find.
I have the same code working great on Windows compiled program on the same Mega2560.
I will NOT go back to version 4.3.4. We are supposed to be moving FORWARD here! I'm on avr-gcc V4.5.1.
Thanks for all your input, guys, but according to my scorecard at the bottom of the first inning (or end of the first period):
Arduino 0
Atmel 0
EDIT: One of these companies could score the first point by posting this:
"Hi, I work for _______, and we are looking into it".
I should start a poll. Am I the only user that can compile programs with avr-gcc V4.5.1?
Without modification, it will not compile "blink".
I am not just shouting accusations at anyone. If you take a look at the other subject, you will see I know where the two bugs are, and I know how to remove them. I have not had time to dig into the client.read() problem yet. I have work to do.
I don't think that the requirement to register is strictly legal (and by legal I mean what the common people think, not some kind of lawyer), at the very least it is a very bad habit.
The compiler IS open source. Therefore access to it should not require anything except clicking on the download link.
anne19:
Hey I couldn't agree more with you! I always tell my students the same thing
Iluvatar:
And you are using the latest Atmel compiler?
avr-gcc --version
My bad. I did not intend to sound so short. Some older versions apparently work fine.
But if you were to start TODAY, with the programs you have available on the internet, could you compile Atmel code?
Arduino V0022
Atmel V4.5.1
EDIT: This has been on here for a while, and I do not see a single post that says "I use V4.5.1, and it works fine right out of the box!".
You don't need anything. That is what I just said. Some previous versions work FINE!
EDIT: Let me be a little more specific here. DO NOT download the new compiler. It does not work!
But the version in my repository (V4.4.2), and the current version that you would download TODAY from the Atmel website (V4.5.1), will NOT compile Atmel code. This is specific to the current versions you download TODAY!
The question is still open. Does anyone besides me have avr-gcc V4.5.1 compiling and running "blink"?
Mine does. Blink - blink - blink
This is Atmel's current compiler and I'm just a newbie!
SCOOOOORRRRRE!! The Arduino team draws first blood. A moderator responded.
The score at the bottom of the second inning (end of the second period)
Arduino 1
Atmel 0
@ moderators: Thanks for not locking this subject and throwing me off the forum. I should give you a free point just for that. I can be a pain in the backside.
